Shudder When Accelerating at First
Old Sep 13, 2018 | 03:08 PM
LLLC1393's Avatar
I always use Eco Mode. I have a very light and moderate foot. I drive fairly slowly as a general rule. That's just my style. When I start out from a stop, there is a shudder when accelerating past about 15-20 MPH or so. I've tried taking the Eco Mode off, but then the whole throttle response changes and it's difficult to make a comparison. I'm quite used to the response in Eco Mode when accelerating gently from a stop. Anyone else notice this uneven behavior?
Old Sep 13, 2018 | 04:18 PM
Shadow Smith's Avatar
I sometimes get a shudder as well. I took mine off economy mode and started using premium fuel and really pushing the engine pretty hard for the past week. It seems to be driving even better now.
I am curious to see if the weather impacts me. I used to notice this behavior more in the winter.
Steve
Old Sep 13, 2018 | 04:49 PM
LLLC1393's Avatar
Steve
Are you still driving hard now? What's the rationale behind using premium fuel. Years ago I was told that it's good to step on the pedal and clear things out from time time, especially for a car that's driven gently. I had all but forgotten about that.
Old Sep 13, 2018 | 05:01 PM
I've had a lot of exotics over the years and the above is called an Italian Tune-up. I think it's supposed to clear carbon build-up. I'm guilty of driving "too easy" on my Fit so I thought I'd mix it up a bit and really get her over 4K RPMs this week. I might put her back in economy mode tomorrow and see how she drives. I might have to add one of those catch-cans if that's supposed to help these DI engines.
Old Sep 13, 2018 | 06:42 PM
LLLC1393's Avatar
I'll be interested to hear how things are when you return to Eco Mode and lower revs.
Old Sep 13, 2018 | 07:47 PM
ur sig shows 2010..? should post in the 2nd gen section.
Old Sep 14, 2018 | 04:17 AM
LLLC1393's Avatar
I have a 2010 and a 2015. This is about the 2015
Old Sep 14, 2018 | 06:25 AM
Fuelish's Avatar
Have you ever noticed at what RPM this is occurring at? (Am assuming the automatics have a tach as well....) If it happens around 2200 RPM, Honda apparently feels this is "normal" … I have a manual, I just accelerate in each gear high enough so that when I upshift, I'm above 2200 RPM when I hit the next gear and never notice it (other than in 1st) ...of course, your situation might be something different, but, just putting that out there.....there've been other threads on here about the hesitation/jutter around that RPM point. Hope you get it sorted
Old Sep 14, 2018 | 05:43 PM
LLLC1393's Avatar
Although I’ve not looked at the tach, it only occurs at the speeds mentioned above and not again.
Old Sep 16, 2018 | 10:08 AM
redracer's Avatar
I get the shudder only when making moderate pull-offs, like merging into low moving traffic, or trying not to jerk the wife's head off on launch. Will usually just go ahead and shift and blip the throttle a couple of times. Haven't figured out the cause.
Old Sep 22, 2018 | 07:04 PM
LLLC1393's Avatar
I tried driving with Eco Mode off and my initial thoughts are that the shuddering only occurs with Eco Mode on. I have a very gentle and moderate foot, and this has caused me to notice slight hesitations etc in some of my previous cars at times. My summation: R.I.P. Econ Mode
Old Oct 4, 2018 | 09:45 AM
LLLC1393's Avatar
Update: The shudder still occurs in Econ Mode or not. Always when accelerating from a stop relatively gently and as you go through 20 MPH. Sigh
Old Oct 4, 2018 | 10:09 AM
bill bosco's Avatar
my LX 6 speed does that every once and a while , i have a light foot , and my clutches never wear out . i find that with the fit you have be kind of deliberate on
throttle tip in . if you feather the pedal a little too much it can shudder a bit . i think it has to do with the way the engine is calibrated . find that sweet spot and the car
accelerates just fine
Old Oct 4, 2018 | 10:18 AM
LLLC1393's Avatar
Thank you for the reply and explanation. I have a hard time putting my foot down, and have for many years. It's about frugality and babying the car. Always trying to make things in general last. I find that when driving my wife's Fit, I can put my foot down and enjoy the car more. I should try a little more acceleration with mine and see what happens. As I stated in previous response, I have been trying to drive more and focus less on the nuances. I'll be off to do some errands in a bit and will try to punch it a bit
Old Nov 16, 2024 | 08:43 PM
RICO_FIT's Avatar
Chiming in here from the future with a CPO 2019 LX CVT. I notice this behavior a lot driving and stop/starting in NYC traffic with light throttle and eco on almost always around 1000rpm. I found this thread looking for info on this issue. It shudders but rpms don't drop from what I can tell.
yuffers
Sep 6, 2016 07:03 PM
FitfulKenny
May 14, 2015 08:27 PM
TCMIV
Dec 21, 2010 02:11 PM
604FIT
Canada Fit Forums & Clubs
May 17, 2006 07:40 PM
lee_hacken
Apr 30, 2006 11:11 PM
