Cleaning up fuel injectors
Old Sep 18, 2019 | 10:28 AM
Gustavo Valdespin Ibarra's Avatar
Hello
I'm trying to clean fuel injectors of my Honda Fit 2015, with a simple DIY pressurized system. For this, I disabled the fuel pump by taking out the 15A fuse. Next, I localized the fuel inlet of the fuel injector rail and connect my pressurized system with the cleaning fluid, instead of the fuel line. I set the pressure to 40 PSI and started up the engine.
I tried this several times by changing the pressure to 45 PSI, 50 PSI and 55 PSI. But the engine didn't start.
I don't know if there is a fuel return line that maybe is causing some issues or the pressure inlet of the cleaning fluid is not the correct one.
I hope you can help me. Thanks
Old Sep 18, 2019 | 10:36 AM
2Rismo2's Avatar
Was the car able to start before this cleaning process? Why was the cleaning process done?
Any engine codes displayed after the cleaning process?
Old Sep 18, 2019 | 10:52 AM
Yes, the car was working well. I'm trying to clean the injectors as part of maintenance. No engine codes appears, only a message on the screen saying "check charge system" I assume that this message is because I removed the fuse of the fuel pump.
Old Sep 18, 2019 | 12:00 PM
New try
I reconnected all the hoses and the fuel pump fuse as they were in the begining. The engine starts well and no issues happened. I noticed that the engine won't start if the fuel pump fuse is missing, even if the fuel line is connected.
This means that if I want to clean up the fuel injectors, I have to tie up the hose of the fuel input line. So the fuel won't come out and make a huge mess.
Will you recommend another technic for cleaning up?
Old Sep 18, 2019 | 12:01 PM
woof's Avatar
As far as I know the Fit direct injection fuel injectors cannot be cleaned. If there is a problem they have to be replaced. If you look at every single post here dealing with fuel injector problems, you will see that when the car is taken to a Honda dealer and the problem is the fuel injectors then they are replaced. There is never any mention of cleaning them. Never.
There was a Honda document that I read some time ago dealing with a fuel injector problem of some kind and somewhere in the document it clearly stated that the Fit fuel injectors cannot be cleaned - they must be replaced. Unfortunately I don't remember what that document was.
In all of the Honda Fit maintenance information I have never seen anything whatsoever about cleaning required for the Fit injectors. You are trying to do something you shouldn't be doing.
Old Sep 18, 2019 | 12:10 PM
2Rismo2's Avatar
Where in the manual does it say to clean the fuel injectors? Is there a MM code like WTF2 or something like that?
Old Sep 19, 2019 | 01:28 PM
Jazu's Avatar
The only known way to clean fuel injectors (easily) is to run a FI cleaner through the fuel system. Have you tried Chevron Techron fuel system treatment (can run every 1K miles - reco using this in the last 1K miles before you change your oil). Techron does darken the oil a bit but many people have used this long-term.
11hawkinst
Aug 10, 2019 05:55 PM
Myxalplyx
May 11, 2016 12:29 AM
clanbuster
Mar 18, 2010 02:45 PM
hsnt
Nov 5, 2009 04:47 PM
freakyfit
21
Apr 19, 2008 11:50 PM
