Need help. Intermittent warning lights
Old Nov 12, 2019 | 08:10 AM
Rob H's Avatar
I'm getting waring lights come on my dash for traction control, ABS, wheel air pressure and some steering wheel light. If I shut my car off it goes away. Might come back on the next trip or sometimes maybe 10-15 minutes later. When the lights are they are actually indicating that the ABS and traction control is disabled. The cruise control light is unrelated. It's on because I use it. There's no engine codes so I assume it's chassis related? If anyone knows what is causing this it would be appreciated. T
Old Nov 12, 2019 | 12:04 PM
2Rismo2's Avatar
I had something similar happened, check it this thread to see if it's related.
https://www.fitfreak.net/forums/3rd-...ng-lights.html
Old Nov 14, 2019 | 12:32 PM
evilchargerfan's Avatar
in the same boat
I tightened grounds/battery and it seemed to have went away
I also purchased a 51R battery, which is sitting around/will get installed soon ish.... I figured it could be on its way out anyways
Old Apr 1, 2020 | 07:41 PM
Rob H's Avatar
I found the issue. Was a broken wire to the wheel speed sensor. Spliced the wire and fixed the issue. Thanks for the input
lyyre
Jan 15, 2019 01:51 PM
sdavid12
Dec 4, 2017 08:11 AM
SilverEX15
Nov 1, 2017 04:25 PM
addison415
Mar 29, 2017 12:36 PM
tradback
Sep 5, 2010 02:07 PM
