Rear Shock Absorber Replacement
Old Apr 7, 2020 | 08:22 AM
Stuart Bartram's Avatar
Hi,
Firstly, I've done a search but not found what I need... hoping someone can help me out.
I have badly leaking rear shock absorbers, and need to replacement, but there's no easy access to the top of the strut like the 2nd Generation.
I guess it's a TRIM REMOVAL job... but I can't find a useful guide anywhere, does anyone have a link?
Thanks
Stuart
Old Apr 7, 2020 | 09:28 AM
2Rismo2's Avatar
Originally Posted by Stuart Bartram
Hi,
Thanks
Stuart
The felt backing can be pulled back. I recall some threads but they escape me right now, but it's doable. Look for ActionJackson's or BassGuitarist.
Old Apr 7, 2020 | 09:29 PM
Bassguitarist1985's Avatar
The felt is held in by push clips. Put the back seats down, open back doors, remove spare tire foam tray, pull away the rear door seals as they hold the felt too, and remove plastic threshold piece bottom of hatch. You can use your fingers or use a plastic pry tool set. Do one side at a time as you need to gently fold away the felt.
22ft/lb for the top mount
40ft/lb for the bottom mount
Good luck and cheers!
Bass
Old Apr 7, 2020 | 11:02 PM
Action Jackson's Avatar
That should give you an idea of how it looks:
https://www.fitfreak.net/forums/3rd-...ml#post1400716
https://www.fitfreak.net/forums/3rd-...ml#post1427587
Jberri
Oct 4, 2022 05:20 PM
1Gr8GE8
May 4, 2014 12:18 PM
mkok
Mar 30, 2014 12:40 PM
storm
Jun 21, 2009 06:56 AM
ChrisG
Nov 18, 2008 11:11 AM
