Drain Plug Torque Specifications?
Old Jan 16, 2020 | 10:00 AM
RavenManiac's Avatar
Does anyone have the torque specifications for the oil and transmission fluid drain plugs on a 2017 Honda Fit EX?
Thanks,
Kelly
Old Jan 16, 2020 | 10:21 AM
marmaladedad's Avatar
Assuming the specification has not changed since my GE and your GK, my owner's manual calls for 29lb/ft (39N/m or 4.0kgf/m) of torque.
The trans fluid drain plug is roughly 35lb/ft, if memory serves. (Google says 36)
Old Jan 16, 2020 | 11:00 AM
evilchargerfan's Avatar
already answered in the K.I.S.S thread:
https://www.fitfreak.net/forums/3rd-...nce-guide.html
theres even a sweet youtube video on how the process is done
as for the 2nd question, someone on here shared access to the Chilton Library, you could easily utilize that to locate TQ specs for the trans fluid drain plug.
Old Jan 16, 2020 | 11:05 AM
GolNat's Avatar
1/4 of a yeet will do.
Old Jan 16, 2020 | 01:24 PM
fujisawa's Avatar
I have never had a car come back from a service with that bolt only tightened to 30lb ft. Generally they’re on tight enough you have to kick the wrench to have it release next time. In other words, I wouldn’t worry about it. Nobody else is.
Old Jan 16, 2020 | 01:34 PM
Odie's Avatar
Draw line with permanent black sharpie on nut and on pan that line up before removal . Used this for drainage of manual tranny .
fujisawa
Jun 29, 2023 04:36 AM
Ogrelode
Mar 12, 2019 02:46 PM
vwli
Mar 11, 2016 10:24 PM
lamyun
Mar 12, 2013 09:18 PM
GC617289
Jul 7, 2012 11:25 AM
