3rd Gen Oxygen Sensor - What To Buy
Old Aug 27, 2020 | 02:21 AM
Slick Seal's Avatar
Question 3rd Gen Oxygen Sensor - What To Buy
Looking to get a new oxygen sensor for bae, but I'm confused about what to get. Is there a difference between the upstream and downstream oxygen sensor? The OEM ones I've seen so far are advertised as "upstream" sensors, so it seems like there is a difference between the two...but I don't see any "downstream" ones available. Here's what I see:
=4&vehicle[liter]=1%2E5&vehicle[submodel]=LX&vehicle[model]=Fit&vehicle[make]=Honda&vehicle[year]=2015]https://www.carparts.com/oxygen-sensor/denso/np2349146?&vehicle[cylinders]=4&vehicle[liter]=1%2E5&vehicle[submodel]=LX&vehicle[model]=Fit&vehicle[make]=Honda&vehicle[year]=2015
As a side note, I'm planning to start with the upstream sensor, because the voltage readings don't appear to be changing (oscillating, etc.) like they should be when I keep it at a constant RPM. Another note, my meter doesn't let me measure voltage on the downstream one for whatever reason, and my meter only shows current readings for it. Again, not really sure why.
Any help is appreciated!
Old Aug 27, 2020 | 05:17 AM
Frenzal's Avatar
Look on Rock Auto, they have the downstream one. The sensor itself is probably the same, but the wires might have different length...
Old Aug 27, 2020 | 10:48 PM
Slick Seal's Avatar
Thumbs up
I don't see the Denso downstream sensor on Rock Auto, maybe I'm just blind. On Autozone, it also appears that the sensors are potentially different, which is unfortunate. Here's what I found:
https://www.autozone.com/emission-control-and-exhaust/oxygen-sensor/denso-exact-fit-oxygen-sensor-234-4978/269751_4610_40154_98000
https://www.autozone.com/emission-control-and-exhaust/oxygen-sensor/denso-exact-fit-oxygen-sensor-234-9146/269989_562832_18264_97999
rwjd
Apr 12, 2024 11:54 AM
fitowner10
Mar 9, 2019 09:02 PM
Captain Bemo
Oct 22, 2016 09:05 PM
leonine
Nov 9, 2006 11:23 AM
