GK5 CVT transmission Oil Filter, should it be changed?
Old Sep 13, 2020 | 07:31 PM
Kevindhe95's Avatar
Item 5 is the transmission oil filter and item 6 is the warmer For coolant to trans oil.
My 2016 Honda Fit LX is currently at 26,827 mileage and im planning ahead to replace the transmission oil at 30,000 miles.
My question is should i attempt to replace the transmission oil filter or would this cause more harm than good by contaminating oil with coolant as i disassemble it. Should i leave it alone regarding the trans oil filter.
what would you recommend and how would you keep the different liquids from contaminating each other if you decide replacing it is the best.
Old Sep 18, 2020 | 05:50 AM
MrPeeps's Avatar
The manual does not have a service for the transmission filter. That seems like overkill for 30k miles anyways.
I have a 2016 and have changed the transmission fluid (not the filter) twice, at 45k and 90k. I believe the 30k interval is suggested somewhere, and is probably a good idea. But I go by the service minder on the car.
Old Sep 18, 2020 | 11:29 AM
JorbNorb's Avatar
Can't hurt. Lifetime filters don't exist IMO. That's what they call the ATF warmer btw at #6 and the ATF warmer filter at #5. The strainer filter is inside the transmission. If I was gonna do it, I'd replace items 5, 6, 7, 8, 9.
hydrocynus
Sep 18, 2020 11:37 AM
Odie
28
Apr 4, 2013 01:43 PM
FitsMePerfect
Sep 21, 2011 03:55 PM
Brain Champagne
Feb 7, 2011 11:44 AM
helphelp911
16
May 31, 2010 09:12 AM
