What is this grinding noise on startup?
Old Oct 14, 2020 | 12:24 PM
Johnnyluck87's Avatar
Hey everybody. I'm new here and looking for an answer. I drive a 2015 fit. As the weather gets colder, I get this horrible grinding noise immediately upon starting the car. It sometimes happens when it didn't get that cold. It has been happening basically since owning the car. Any insights on this issue? Thanks.
Old Oct 14, 2020 | 05:36 PM
GolNat's Avatar
Starter bendix might be sticking or wore out.
Old Dec 22, 2020 | 02:40 PM
Eightdogbutts's Avatar
Engine rattles on cold start up
On service bulletin it says:
Symptom: at cold start up the engine rattles loudly for about 2 seconds, may be intermittent and occurs on cold starts where the engine typically has not been started 6-8 hours
Possible causes: The variable valve timing control (VTC) actuator is defective on 2015-2016 Fit models all trims all vins
Corrective action: Replace the VTC actuator
(needs special tools)
Old Jul 25, 2023 | 10:14 AM
kanadary's Avatar
is this tsb repair covered even if the car is out of warrantee?
Old Jul 26, 2023 | 10:57 AM
NWCH's Avatar
Normal issue for the 2015's and up. It's for sure the VTC actuator. We just paid $1500 to have Honda fix on our 2018 Sport. And the noise just came back a year later. It doesn't effect anything. Just makes noise on cold starts. Now I'll just deal with it. Not worth fixing when it wears out super fast.
NWCH's Avatar
No. This fix is only covered by the vehicles owner.
Hondafit11
Aug 31, 2020 07:47 PM
Martha Campagna
Nov 28, 2018 09:35 PM
pipcorona
Jul 16, 2014 06:10 AM
fujisawa
Aug 7, 2012 05:52 PM
NBPturtle
May 29, 2008 09:52 AM
