Confirm part numbers for Transmission Fluid Washers for 2019 Fit
Old Sep 11, 2023 | 06:49 PM
Kirkland's Avatar
I found the part number for transmission fluid check plug on here 94109-20000. I received the order but the washer looks pretty big for a check plug. I also would like to check the part number for the transmission fluid drain plug.
Thanks for the help.
Old Sep 11, 2023 | 07:23 PM
Hootie's Avatar
94109-20000 - Fill Port crush washer
90471-PX4-000 - Drain Plug crush Washer
Torque spec for both is 32 lb ft for CVT cars. Fluid capacity for CVT should be around 3.6 qts of HCF-2 (08200-HCF2).
There is a fill port on the top of the transmission case that you can access by removing the air box assembly. Its so much easier than using a pump and going through the check plug.
Old Sep 13, 2023 | 02:13 PM
tedhh's Avatar
Raybisono
Apr 26, 2023 03:24 PM
domromer
Feb 19, 2019 06:37 PM
kaede1337
Jul 31, 2016 05:22 PM
vwli
Mar 11, 2016 10:24 PM
xander
Feb 2, 2009 01:50 PM
