Oil/Coolant
Old Oct 24, 2014 | 03:26 AM
s0x's Avatar
s0x
Originally Posted by 13fit
If Evans waterless is so effective, why is it not widely used? I will be honest, I have not heard of it (perhaps its recently developed?)
Ive been around several speed shops and mechanics, I think the only real cooling system setup Ive heard effective was that water-wetter additive when applied to a properly setup cooling system. Else good fans and no air bubbles makes the engine happy
its not widely used i believe because its A) Much more expensive for the manufacturer to use in new cars, not to mention this means that all those wear and tear components don't wear out as well as taking away the service departments money from charging upwards of 100 dollars to undo one plastic bolt and "flushing" the coolant. and B) its kind of a pain in the butt to do the conversion for the average person. You have to flush the system and then make sure its completely dry. The first gen fit is apox 1.5 gallons of coolant and evens becomes ineffective if there is more than 3% water in the system. Which means the maximum amount of water that the system can handle without loosing effectiveness is 5oz.
my opinion.
Old Oct 24, 2014 | 04:48 AM
Black3sr's Avatar
All this is nonsense. This is a new car. There is no need to be screwing around trying to add oil or coolant. If it needs either have dealer check it out as it could be a problem otherwise relax and enjoy.
My two cents worth.
Old Oct 24, 2014 | 10:43 AM
kbonus's Avatar
I am the only one wondering how you got along without a car for 35 years? I could see this if you lived in say, New York, or a major city in Europe. But the rest of the USA? I'd be interested to hear how your experience has been in your triumphant return to the motoring world. Thanks!
Old Oct 24, 2014 | 10:57 AM
mecevans's Avatar
What do I know. I'm just a stupid master tech.
Old Oct 24, 2014 | 11:31 AM
CyclingFit's Avatar
Very simple read. Explains that if mixing, this is what you should expect or how it will effect your interval. With service interval in mind.... If you are topping off, you likely aren't concerned with the proper service interval.
Universal Coolants
The link below is awesome. A few chemistry terms but nothing over the top. This is the one to read if you only want to read one.
Engine Coolants
Key takeaways are acids ability to react with silicone used in gaskets and the life expectancy of different types.
Correction to what I said earlier about reaction with plastic... It's not breaking the plastic but many gaskets are a solid plastic gasket with a silicone layer that actually does the sealing.
Old Oct 24, 2014 | 11:46 AM
exl500's Avatar
kbonus, I did in fact live in Manhattan from 1979 until this June. All of my automotive experience is with rentals for 35 years. I absolutely love having the car to use whenever I want or to leave it when I don't. I am simply clueless about maintenance intervals. Since the manual says check every time you refuel (which even I realize is crazy) I've been figuring once a month. I'm sure Black3sr is absolutely right and I'm totally over-reacting. The oil level is fine, and I can't be sure I'm reading the coolant right. There seems to be a fair amount in there.
Old Oct 24, 2014 | 01:38 PM
kbonus's Avatar
EXL500: Thanks for the history. Enjoy the FIT. I've sure been happy with mine so far.
Old Oct 24, 2014 | 01:44 PM
on my '12, i use mobil1 green cap. for coolant honda type2, i think it was called. it's already mixed, ready to use.
Old Oct 24, 2014 | 03:39 PM
s0x's Avatar
s0x
on this topic... ken do you know if the first gen fits had green coolant? I can clearly remember (I've had my car since there were 4 miles on the tac) that I've never done a coolant flush or change but my coolant (before i decided to switch to evans) was bright green NOT blue like honda coolant. so A) did my dealership skimp. B) did someone do this while my car was in the shop for something at some point and didn't tell me or C) did honda coolant used to be green? Anyone know?
Old Oct 25, 2014 | 01:19 PM
doctordoom's Avatar
Supervillain
^My first gen had the blue (long life) coolant. That's why we all get 100k mile coolant replacement intervals haha.
Old Oct 26, 2014 | 05:32 AM
s0x's Avatar
s0x
dang i wonder when my system got flushed with the green one lol
spookyneo
Nov 20, 2017 12:05 AM
exl500
Jun 14, 2017 10:36 AM
wackyflik
Mar 6, 2013 04:00 AM
Spooling
Nov 22, 2008 03:37 AM
mmdir2002@yahoo.co.uk
May 4, 2005 04:44 PM
