Serpentine belt
Old Mar 3, 2018 | 12:48 PM
robs's Avatar
Serpentine belt
Anyone changed theirs yet? Tough?
Had to buy one for my son's Jeep at RockAuto, Gates was only $11 bucks so I bought one since I had to pay shipping anyway.
Old Mar 3, 2018 | 06:15 PM
ezone's Avatar
Does yours actually need replaced?
I pretty much expect more than 10 years/100k miles out of these belts nowadays
If you can replace the belt on a Jeep, the Fit should be easy.
Old Mar 4, 2018 | 09:58 AM
James Butler's Avatar
Maybe this will help
Old Mar 4, 2018 | 08:41 PM
robs's Avatar
I'm at 82k miles. The graphic helps. Thanks!
Old Mar 13, 2018 | 03:47 PM
Uncle Gary's Avatar
There are a couple of marks on the adjuster that indicate when the belt has stretched.
Old May 7, 2018 | 09:12 PM
Alco RS-1's Avatar
Does anyone know if the process on the GE (Gen2) Fit is the same? The GE has an auto-tensioner.
Old May 7, 2018 | 10:59 PM
Try this for 2nd gen Fit
Old Jul 4, 2018 | 09:00 AM
Alfa38's Avatar
Our "new" 2011 Sport has 94k miles. Is there a recommended change interval for the serpentine belt and tensioner/idler pulleys? I've had the pulleys catastrophically fail on a car before, on a trip, and it was a mess I'd like to avoid. Wondering if its time to change, and do you change the tensioner at the same time as a preventative maintenance.
Old Jul 4, 2018 | 10:39 AM
Alco RS-1's Avatar
Originally Posted by James Butler
Try this for 2nd gen Fit …
Thanks very much! Just what I was looking for.
Old Jul 4, 2018 | 10:54 AM
ezone's Avatar
Not really. "When something goes bad"?
IMO the belt is easy to check, look for many big cracks along the grooved surface.
If you take the belt off you can spin the pulley(s) by hand and listen/feel for unusual roughness.
Most bearing failures will give a fair amount of warning before there's a "spectacular event". The bearing usually makes noise, but a person might need to be pretty observant to new noises to notice a small bearing in the very beginning stages of failure.
OTOH some people are completely oblivious to all kinds of issues as long as they can put fuel in the tank and the car will pull itself down the road.
My GF is one of the latter. Her 07 Fit has close to 250k on it now. I replaced the compressor pulley, idler pulley, and serp belt around 200k, mainly because I was already into the engine for other stuff at the same time.
Old Jul 4, 2018 | 11:31 AM
4d_POWER's Avatar
Just replaced my ‘15 Ex serp @ 130k.
Belt was very hard to remove and replace. The belt is TIGHT! Pinned the tensioner like the graphic shows, wasn’t enough, had to push on the tensioner even more, still was difficult. Belt came off with much much gentle persuasion. Belt went back on using Claycolvin’s method in this thread; https://www.fitfreak.net/forums/2nd-...tine-belt.html
Good Fun!! Lol enjoy
Old Jul 5, 2018 | 02:42 AM
Kdawgz's Avatar
You will need to remove the passenger tire and splash guard. It's actually not that bad. Took me about an hour and half to do.
Old Aug 17, 2019 | 10:20 AM
robs's Avatar
Yeah, what 4d_POWER said. This was a MAJOR PITA. I'm at 115k, and the belt was 100% toast. Missing ribs, multiple cracks per inch. Hopefully it's better on later models, but I've got an early 2015. I was on a friends lift and it took both of us to get it back on. Him under the car and me on a ladder so we could get the new one over the idler under the alternator.
mikejet
Sep 22, 2021 11:04 PM
Marrk
Apr 11, 2017 10:52 PM
hazzard
Nov 20, 2013 01:38 AM
craigquakertown
Nov 23, 2012 12:49 PM
