8mm bolt in bottom of head unit?
Old Jun 27, 2019 | 03:42 PM
seditious3's Avatar
2016 EX. I've got everything disassembled, but cannot find the 8mm bolt at the bottom. Help please? Thanks!
Edit: After removing only the top 2 bolts, the head unit seems to move somewhat freely. It can pull out a half inch or so, but it gets stuck on the lower left. The snap holds are cleared. Any ideas?
Old Jun 27, 2019 | 09:09 PM
Bassguitarist1985's Avatar
Single bolt aimed up to the HU on the left you need to remove. Need to remove the usb and hdmi panel. There is one screw on there. Disconnect it, set to the side. Then you can get access to HU bolt. Check my thread. Be careful not to lose it in the floor vent where the center console is. Otherwise you will be repeating various 4 letter words till you fish it out with a magnet on a stick.
Old Jun 27, 2019 | 11:37 PM
seditious3's Avatar
I've got the usb/hdmi panel removed. You say the bolt goes straight up and is on the left? Is it on the HU or on a bracket connected to the HU? I have your wiring harness all set to go.
Old Jun 27, 2019 | 11:53 PM
Action Jackson's Avatar
https://www.fitfreak.net/forums/3rd-...-2015-fit.html
It's annoying trying to find the first time.
Old Jun 30, 2019 | 07:05 PM
seditious3's Avatar
Thanks all!
craycraypixel
Jun 14, 2018 11:12 PM
Cordizzle4life
Mar 21, 2014 05:45 PM
davela72
Feb 3, 2009 04:53 PM
mattschechter
Jul 12, 2006 02:17 PM
Gerry
May 4, 2005 11:16 AM
