Hands free doesn't recognize stored phone #s bluetooth
Old May 14, 2015 | 05:10 PM
etana's Avatar
I have a 4-month old 2015 Fit Silver LX CVT which I love, and an iPhone 6+ which I love.
Mostly i press the steering wheel phone button, the computer says, 'say a command;' I say, 'phone Carol mobile,' and everything works great.
Sometimes it doesn't, and the computer says #00 add more numbers, or something like that, so it can dial the number..
When I shut the car and restart it, the problem is fixed, but I can't do that on the road while driving.
Another issue is that sometimes when the phone call does work, the volume is totally low, and I can't make it louder. Usually the volume is high enough, and can be controlled by the radio volume dial.
Do I need to take it in for service, or what is going on?
thanks in advance, Etana
Old May 14, 2015 | 06:17 PM
thedrummingfish's Avatar
That is really weird. I'm on an android so I don't know that I have much info on the iPhone side. Only thing I've run into is that some of the contacts didn't bring a name over with the phone number.
Worth checking the settings section for "automatically sync phone data" and make sure it is set to "yes".
Edit: I've also found things move much smoother if you have BT enabled on your phone before starting the car.
Old May 14, 2015 | 07:30 PM
Redd's Avatar
I have this same problem except it almost always does not work. I end up using speed dial buttons on the head unit.
Old May 17, 2015 | 01:14 AM
etana's Avatar
I think I didn't explain clearly enough.
I have a few family/friends who I have programmed into the hands free, such as
"phone Carol mobile" and I programmed in the phone number. I press the button on the steering wheel, and usually I can at the prompt say, "phone Carol mobile" and the call goes through.
But sometimes it doesn't, and instead the computer prompt says, "#00 dial the rest of the number" or something like that.
So that's one part of the problem. I do know that I can use Siri on my iPhone by holding down the home button on my iPhone to have Siri call my other contacts that I didn't program into the Honda Fit Hands Free.
The other part of the problem, is that usually the volume is fine from the caller, or the person I phone, but sometimes the volume is way down. I know the radio dial on the left can adjust the volume usually, but on the times when the caller is on low volume, I cannot make the volume louder.
I tried turning off the car and restarting it, and the Hands Free and volume worked. But I can't be driving along on the highway and stop and turn off the car to reset the Hands Free.
I phoned Honda Service but they just said, 'bring the car in.' I googled but couldn't find anything relevant.
NOTE: I always have bluetooth enabled on my iPhone.
I haven't set this up yet for the car to access my contacts, I may not do this at all. I just manually entered 6 contacts phone numbers and the recording "phone Carol mobile" etc.
thanks, Etana
Old May 17, 2015 | 01:45 AM
You can use Siri through bt if you hold the center button on the phone controls on the steering wheel. It sounds like you have a lot of competing inputs between bt audio, contacts on car, making calls over the phone through bt as a "third party" instead of directly accessing the phone book on your phone, volume of your phone (typically multiple settings for bt, media, call, etc). Just my 2 cents :-)
Old May 17, 2015 | 05:47 PM
etana's Avatar
I tried unsuccessfully to hold the center button on the phone controls on the steering wheel. Nothing happened. My iPhone 6+ IS connected bluetooth to the car. Can you explain how to use Siri using the controls on the steering wheel. That would work fine for me. Thanks.
Old May 17, 2015 | 10:33 PM
Hmm I have an EX so maybe a trim difference. I'm on android so all I get is a sad little "this smartphone is not supported message", but I read about it in the manual...
Old May 17, 2015 | 11:09 PM
Redd's Avatar
Yes, Siri doesn't work on the LX
Old May 21, 2015 | 04:05 PM
Tway's Avatar
I have an iPhone 5s, and I have noticed this problem. Have you tried the age old answer.....turn the PHONE itself off?
I drive a 2015 LX MT so hands-free is the only way I am able to operate or do anything. When I have syncing and BT issues with my phone i just restart the damn phone and everything works perfectly fine again.
I found its sometimes a matter of having too much backround apps operating on the phone.
Old May 21, 2015 | 04:34 PM
etana's Avatar
Yes, when I restart the phone, it fixes it, but I have to pull over while driving to do that. I don't think the background apps would be an issue, but I'll look into that too.
Nero27
Sep 12, 2018 09:29 AM
puffysweater
Apr 30, 2017 09:31 PM
SilverEX15
Aug 15, 2015 08:55 PM
Sz28r
Aug 6, 2015 10:15 AM
BarrieFit
Jan 2, 2015 07:09 PM
