3rd Generation GK Specific Suspension & Brakes Sub-Forum Threads discussing suspension and brake related modifications for the 3rd generation Honda Fit (GK)
Sway Bars
Old Dec 13, 2015 | 04:42 PM
  #101
jhn's Avatar
jhn
I just filled the OE bushings. I didn't even remove them from the axle. I loosened the torsion beam enough to drop it down and filled them with urethane. I let them dry almost two days before I drove the car again.
Old Dec 13, 2015 | 08:40 PM
  #102
Vjaramillo's Avatar
Installed my progress sway bar. Big difference in handling, however, it's constantly knocking against my gas tank. Anyone else have this problem?
Old Dec 13, 2015 | 08:45 PM
  #103
2Rismo2's Avatar
You must mean the spare tire area since the gas tank is under the front seats. In this thread, it appears you have lowering springs? Could that be contributing to the clearance issue?
If it is in fact hitting the gas tank, I don't think it's installed correctly?
Old Dec 13, 2015 | 11:03 PM
  #104
Vjaramillo's Avatar
Rismo. Thanks for the clarification. Yes. The spare tire compartment.
Old Dec 14, 2015 | 06:30 PM
  #105
kkim's Avatar
do you have a picture of your install? Mine does not hit anything.
Old Dec 15, 2015 | 09:20 AM
  #106
bigbacon's Avatar
mine is not knocking on anything. do you have any other suspension changes over stock?You made sure that you torqued everything down well? maybe there is play at one of the mount points.
Old Dec 15, 2015 | 06:22 PM
  #107
Vjaramillo's Avatar
Tech guy told me to losen, push back as far as possible and re torque. Hopefully that will work.
Old Dec 17, 2015 | 04:05 PM
  #108
2Rismo2's Avatar
Still getting interference?
Old Dec 17, 2015 | 05:30 PM
  #109
Vjaramillo's Avatar
Haven't had the chance yet. I will reinstall this weekend and cross my fingers.
Old Dec 17, 2015 | 07:32 PM
  #110
2Rismo2's Avatar
Hopefully that'll do the trick. I still have to buy the sway bar, probably after Christmas as my credit cards are on fire with all the holiday shopping.
Old Dec 19, 2015 | 05:55 PM
  #111
Vjaramillo's Avatar
Finally worked. No knocking even though it looks pretty close to the spare tire compartment. So here's my tip on installing the sway. The first time I had the car on jack stands. This time I used my ramps so springs were compressed vs dangling. I use clamps to bring the bar as close as possible to the cars rear structure then tightened and torqued to spec. Handles much bette than before.
Old Dec 20, 2015 | 01:02 PM
  #112
Oneoldphlaytis's Avatar
Why did you do this? What are the advantages and potential downsides and where did you get it from?
thanks
Old Dec 20, 2015 | 01:45 PM
  #113
Vjaramillo's Avatar
Oh and my car is lowered on tanabe springs. Forgot to mention that.
Old Dec 20, 2015 | 02:31 PM
  #114
TofuShop's Avatar
Offtopic: is that a Spoon muffler? vids?
Old Dec 20, 2015 | 05:40 PM
  #115
Vjaramillo's Avatar
Yep. Love it. Will once it stops raining.
Old Dec 20, 2015 | 06:17 PM
  #116
Myxalplyx's Avatar
Originally Posted by bigbacon
Once my wife gets a chance to drive it I could add her thoughts because she always complained a well about the excessive body lean and rebounding.
Did your wife get a chance to comment? Interested in knowing because my wife drives the Fit now.
Old Dec 21, 2015 | 02:33 PM
  #117
jhn's Avatar
jhn
thanks
Mainly because I am not happy with the excessive understeer. Even with all the mods I've done I'm still getting it. I filled them to stiffen them. This is an attempt to reduce the float inherent in compliance bushing design that increases understeer (rear bushings). It makes the car feel more solid. It makes the car ride harsher too so it's not for the person seeking comfort.
I used 3M 8609 urethane. I would like to do the front bushings soon as well. I'll either swap them for Hardrace of fill them w/ Energy Suspension 60a.
Here's a good video demonstrating how much these things float around:
Old Dec 30, 2015 | 07:57 AM
  #118
robertsmithfromthecure's Avatar
I would also love to see/hear a video on your Spoon muffler! Please please please!
Old Dec 30, 2015 | 12:43 PM
  #119
dwtaylorpdx's Avatar
Stiffening the front will not usually help understeer, usually you stiffen the rear to make the car turn in.. Or increase air pressure in the rear tires slightly. Or reduce front tire air pressure a lb or 2.. As you stiffen the car up, it will respond more to the small changes..
Adding rear sway bar usually increases turn in.
Old Dec 30, 2015 | 04:12 PM
  #120
Vjaramillo's Avatar
