Rear air shock absorber mod
@JHN,
here are the pictures and video to follow. You made a good point about the air shock being shorter overall than OEM. So I went ahead and extended the upper stem. I put loctite on all the nuts so it don't go nowhere. I also was able to reuse the stock bump stop by removing it from the plastic dust cover. The extended upper stem allowed me to get the extended length exactly equal to OEM.
I actually used the MA811's instead of the MA793. The MA793 is an acceptable substitute if one were to use them without the bump stop and without extending the upper stem. Using them with the extended stud and oem bump stop will make the extended length about 1.25" longer than the OEM extended length. This normally isn't a big deal, but if you were to hit a really deep pot hole, the extended travel could cause the spring to fall out of the seating. Again, it will work, but its all up to preference. The positive is you can raise your car a bit higher up (an inch more) if one were to choose.
40PSI in the air shock to level off a 700lb payload.
Update: Converting Air lines from 1/8" to 1/4"
After a few months of driving, these shocks are such an upgrade from the stock shocks. Occasionally towing has been far more convenient than keeping a pickup truck as a secondary utility vehicle.
The AK18 air line kit the Monroe 811 comes with is not what I would call the best choice for air lines. The plastic tee, schrader valve, and compression nuts are questionable reliability for the long term. Not to mention that any type of air suspension sold today (least in the states) uses STANDARDIZED 1/4" air line . I discuss below the necessary parts to convert this air shock product line to 1/4" fittings and make it MUCH easier to source parts and have it be comparable with other air suspension mods in the future.
The Monroe MA series has a male thread port for the air line. The thread is a JIC 7/16-20. You will need a F/F adapter from that thread to a 1/4"-18 NPT female to adapt to standard air line fittings. See link below.
EATON AEROQUIP Hose Adapter,NPT to JIC,7/16-20 x 1/4-18 - Hydraulic Hose Adapters and Plugs - 4VPT3|2242-4-4s - Grainger Industrial Supply
After you install this adapter the sky is the limit. I am using PTC-->1/4" NPT fittings along with PTC brass tee, and PTC flow control valve to negate the "see-saw" effect. 1/4" air line is super easy to source locally. Depending how one would want to setup their shocks is completely up to the user. I may at some point get the Airlift 72000 kit. Looks very slick but a bit pricey. Regardless, I'd love to have it!
Amazon.com: AIR LIFT 72000 Wireless Air Leveling Compressor: Automotive
Nice mod. Don't know which way I will go but I had air bags on a Ford Fusion and they worked great also. Found them for the Fit here.
Suspension Enhancement for 2015 Honda Fit | etrailer.com
do you think I could install similar shocks on the front too?
it would be nice to be able to raise the car from time to time... especially during heavy snow in Canadian winter.
Just a thought,, air shocks shouldn't share the tube to fill the air system they should be separate and checked with a good gauge, if you siamese the pipe to one fitting they can pump each other up on rough roads and cause some serious shimmy..
Not sure if Monroe makes any coil over air shocks. If they do let me know. Id be interested in the same mod. Thats where i can justify a 4 way manifold and digital valve system to manage it
I have since this thread separated the tee fitting to separate fitting with 1/4" tube and PTC connectors. I separate using a shut off tee valve to prevent air flowing to the other shock and it helps a lot. Not a lot of shimmy but a lot of seesaw effect despite the torsion beam thats OEM to the car.
Yosemite
01-20-2015 10:48 PM
mrphilip
10-07-2013 09:34 PM
