3rd Generation GK Specific Suspension & Brakes Sub-Forum Threads discussing suspension and brake related modifications for the 3rd generation Honda Fit (GK)
Jounce Springs
Old Apr 1, 2016 | 08:48 AM
fit419's Avatar
Jounce Springs
Can someone school me on jounce springs/bump stops? What is their function in the GK Fit?
I've seen bits and pieces of info in various threads, and I see mixed opinions on whether they should be modified when lowering the car.
Any info is greatly appreciated!
Old Apr 2, 2016 | 03:11 AM
dwtaylorpdx's Avatar
Bump stops typically are the last resort to keep stuff that shouldn't hit other stuff from hitting stuff.
They get closer when you lower the car and one bandaid is to trim the bump stops to eek out just a bit more travel..
Old Apr 2, 2016 | 07:51 PM
jhn's Avatar
jhn
They are a supplementary spring that also prevents harsh bottoming. When you cut them, it essentially shoftens the early part or the suspension stroke. They get progressively stiffer as they're compressed. The end you shorten can can give different results.
Jounce springs are used in racing to dial in suspension characteristics. They are used mostly in circle track and drag racing but they're becoming more prevalent in road circuits as well.
Old Apr 2, 2016 | 07:57 PM
jhn's Avatar
jhn
Also, the GK uses the jounces pretty much through the entire suspension stroke. When you lower one with lowering springs, it compresses the jounces and this increases the spring rate throughout the stroke. If you cut the small end, say one "donut", it will soften the early stroke compared to one uncut, but it will progress at a faster rate. Cut them at the big end and it won't progress as rapidly. Be careful cutting them though. If they're too short you can coil bind or bottom the shock and this can do damage
Old Apr 3, 2016 | 04:17 PM
fit419's Avatar
Good info! Thanks for the response
Kenn Jethro
Dec 15, 2018 05:11 AM
lsdbaby
Nov 4, 2012 10:29 PM
towelie
Nov 12, 2009 06:35 PM
Ciggy
Apr 13, 2009 07:37 PM
joshua27
19
Jun 15, 2008 08:06 PM
