GE8 2008 Lowering Springs Suggestions?
Old Nov 25, 2018 | 02:38 AM
Kenn Jethro's Avatar
Post GE8 2008 Lowering Springs Suggestions?
Hi. I'm in the market right now looking for lowering springs. Here's my preferred specs;
1.3" Front and 1.5" Rear. otherwise if not available, 1.5" both F and R will do.
Any suggestions as well where I can buy that ships Globally... Because I live in New Zealand.
Peace and have a nice day!
Old Dec 15, 2018 | 05:11 AM
J20's Avatar
J20
any. The softest you can get away with. Just make sure to cut the front bump stops about an inch NO MORE and don't go fast over sharp speed bumps or you will slam. Also cut the rear bump stops and cut the metal sleeve cup for the bump stops as well....or the metal cup will act as a bump stop and it's gonna make a clack sound in the rear if you bottom out. If you carry high loads. More than 250 lbs in the rear frequently get something with higher spring rate. Swift springs for ge8 are the softest. There's a list out there. Make sure you're looking at ge8 lowering spring rates not gd3. Cars gonna fly. Lowered car less body roll. As far as spring rates Remember lower spring rates = more grip softer ride. Higher spring rates less grip harsher ride but less risk of bottoming out.
fit419
3rd Generation GK Specific Suspension & Brakes Sub-Forum
Apr 3, 2016 04:17 PM
YeahItFits
Jun 12, 2014 11:31 PM
lsdbaby
Nov 4, 2012 10:29 PM
Ciggy
Apr 13, 2009 07:37 PM
pwnstar
Oct 15, 2008 09:27 PM
