3rd Generation GK Specific Suspension & Brakes Sub-Forum Threads discussing suspension and brake related modifications for the 3rd generation Honda Fit (GK)
Tein Flex Z coilovers clunk sound driver side on GK
Old Oct 19, 2018 | 12:17 AM
FitHundreds's Avatar
Hi guys,
Anyone experienced clunking sound after installing their tein flex z coilovers? It's not everytime I hit a bump or anything. Sometimes I hear it when turning or random bump. Not sure if its the springs or what. Anyone has experienced this and solved it? Thank you!
Old Oct 19, 2018 | 12:27 AM
GolNat's Avatar
I had no issues with mine. Are you sure everything is tight and all washers, spacers and stuff are there?
Old Oct 19, 2018 | 02:12 AM
I am pretty sure it's all there. It's crazy nothing looks loose in there.
Old Oct 19, 2018 | 09:41 AM
Double check your sway bar endlinks.
Old Oct 19, 2018 | 01:39 PM
evilchargerfan's Avatar
I'm thinking 1 of 3 things:
-end links not tightened (all the way)
-did not tighten the top of the tower and entire assembly can move up/down a bit
-didnt re assemble correctly:
Old Aug 29, 2019 | 09:12 AM
JingJangJoe's Avatar
Yep. Just installed the Flex Z and had the clunk sound at random times. Esp when turning and going over a hump.
Sometimes it clunk, sometimes it doesn't. Sound is coming from the rear.
No problems with the front.
Still figuring out what is causing the sound
Old Aug 29, 2019 | 09:34 AM
yank out your end links
does it still clunk?
Old Aug 29, 2019 | 09:11 PM
End links?
Any pics? Thanks
Ralph Erwin Laranang
Sep 7, 2020 01:52 PM
ozoned
Sep 14, 2012 12:27 AM
koshir
Feb 3, 2008 11:50 PM
michaelfit84
59
Dec 4, 2007 04:25 AM
st3alth
Aug 16, 2006 10:39 PM
