Will a '15 Fit with these wheels work?
Old Oct 28, 2014 | 12:49 PM
ellatron's Avatar
Rota SDX
Bolt pattern: 4x100
Offset: +45mm
Color: Gun Metal
Tires: Nexen N3000 215/45/17
thanks in advance. someone is selling them for $400 and seems like a good deal for an extra set....
Old Oct 28, 2014 | 11:17 PM
economicon's Avatar
Just ran it through a calculator.
http://www.1010tires.com/Tools/Tire-...5R16/215-45R17
It's bigger in overall diameter by 2.5%, it is a bit too big, may not work if you plan to drop the car.
Now what I'm afraid of is the offset. From the calculator 1010TIRES.COM - Wheel Offset Calculator
it says inner clearance will be 11 mm less & it will also extend 27 mm outside.
Ideal width & offset for 17" diameter is 7" & 40 mm, to maintain the same inner clearance as the stock wheels. As for tires, I won't go beyond 215/40R17. Diameter will be about the same as the stock (a little smaller).
Old Oct 29, 2014 | 01:11 PM
Waiz's Avatar
Avid FitFreak Poster
They should be fine, tires might be a tad too big if you ever lower the car but you can swap those out
Old Oct 29, 2014 | 07:00 PM
kenji815's Avatar
215 is a bit wide for 7.5" width rims
i would suggest narrower tires
Sprocket
Nov 10, 2013 02:56 PM
braziers
Jan 30, 2009 05:51 AM
bread bucket
Sep 15, 2008 05:15 PM
sirfit08
Sep 5, 2008 07:32 PM
diedwater
Feb 23, 2008 04:12 PM
