TPMS keeps coming on
Old Nov 12, 2017 | 11:47 AM
sneefy's Avatar
Originally Posted by Musicalpa
My Subaru does have a TPM in the spare. And, as far as when my TPM light went on in my Honda, it was only when I corrected the spare tire pressure that the TPM light remained off, so I am a bit puzzled by that if it doesn't have an internal TPM sensor in the spare.
Your Subaru does not have a sensor in the spare unless you installed it. Subaru has never put a sensor in the temporary spare tire and they have never had a vehicle that can hold more than 4 codes. At least not in the United States. I will wager any amount of money on this. If your light went out after you inflated the spare, it was coincidence.
As for the Fit, also pure coincidence. As of 2015+, there are no sensors in the wheels. It just monitors wheel rotations via the same sensors it uses for traction control. The system cannot monitor the spare while it is in the trunk.
Old Nov 18, 2017 | 06:59 PM
David Lawrence's Avatar
Originally Posted by Bassguitarist1985
Best way to calibrate is to make sure tire pressures are all equal (i set mine to 35psi per tire) Hit the calibrate button, and I'm set for a few months. Tires lose pressure over time and change with temperature. What you speak of having to reset the system every few months makes perfect sense.
Is there any advantage or disadvantage setting the tires to 35psi rather than 33/32 per the specifications?
Old Mar 1, 2019 | 03:06 PM
tdi2fit's Avatar
Thumbs up
(((( Bump ))))
Old Nov 3, 2021 | 04:40 PM
BertZ's Avatar
OP here. Well, I brought the car into the dealer, and just heard back that they noticed one tire had a different tread than the others, and asked if I had a tire replaced recently. Well yes, I did have a tire replaced, but it was a couple of years back. The dealer believed that the light is being triggered by the difference in tread depth between the one new tire vs the three old tires, and suggested I get new tires. I told them I'd think about it, since I believe the old (original) tires still have some good life in them (there is 21K miles on the car).
Thanks for everyone's input.
wasserball
Jun 6, 2018 12:26 PM
TopJimmy5150
Oct 16, 2014 11:16 PM
busharroo
Feb 16, 2014 09:37 PM
Santiad
Feb 23, 2012 02:02 AM
ECGETAWAY
Sep 21, 2010 11:11 PM
