Mods for NA Sport
Old Mar 15, 2019 | 08:36 PM
Piscator's Avatar
Mods for NA Sport
I freely admit that I don’t login much tho I do find TONS of information for maintaining my little Fit. 2007 Fit Sport.
I am now thinking itd be nice (fun) to get a little more out of it. So I’m asking... I’d like to upgrade in steps.
intake first? Exhaust( and even that in steps ie Header then catback etc)? I have no illusions of turning this into my old Firebird Formula. But it’d be nice to get some more get up and go. I’m not currently thinking of boost tho a turbo could eventually be tempting. Or hell, y’all could probably talk me into that if it’s not too horrifically expensive.
Annnd at what point would an ecu tune be appropiate. I live in Md (spits) so if there is reliable shop in my area that’s be great but honestly I could do much myself. I’m mechanically inclined and have done valve adjustments (Fit) and even diff replacements (my Pathfinder) I don’t work fast and I plan slowly, so I’m not in a rush. The threads I’ve found are older so I thought I’d ask. Again 🙄😁.
Im open to suggestions. Thanks in advance.
Old Mar 16, 2019 | 08:29 AM
GolNat's Avatar
No ECU tune needed (don't think one exists for the GE) unless going forced induction.
Honestly bolt on parts don't do much. Intake will make more noise and increase throttle response. Exhaust/headers will increase noise but not add much in the HP department. I'm sure those things do add some but its not much. Best way to make power is adding a supercharger kit or turbo.
Summer tires and coil overs and you will have a fun go cart!!
Old Mar 17, 2019 | 10:55 AM
domoMKIV's Avatar
If you are doing bolt-ons, the only way you are really going to see more power is with a Hondata and tune. Of course, FI will increase power but you'll probably have to piece together your own kit at this point.
I agree with GolNat on the tires and suspension upgrade. Maybe a rear swaybar too. Before you dump money into that though I would make sure all the ball joints, strut mounts, endlinks and engine mounts are in good shape, replace as necessary.
Old Mar 18, 2019 | 12:29 AM
Hootie's Avatar
You're looking for a noticeable jump in power NA, you'll be doing a good bit of digging around with Hondata (which is VERY user friendly) to get the most out of those bolts ons and it might get a little on the expensive side to be honest. Especially if you're going for the 105 WHP and up mark naturally aspirated.
Bang for buck power wise... one step colder spark plug (like Denso IK22), a decent header and catback should put you really close to 100 WHP on a GOOD fuel and ignition tune on 93 with the stock intake. You can attempt to find a better flowing intake than the stock airbox but the factory airbox actually flows decently well. Even Spoon Sports used a lightly modified version of the stock box in their racecar to be honest. Other intakes like the AFE Stage 2 for example might make a pinch less peak WHP but will pick up noticeably more WTQ lower in the RPM band. I personally have gone from a baseline of about 92 WHP (untuned with the following bolt ons) to 104 WHP on my automatic sport by simply doing fuel tuning on 93 octane via Hondata, one step colder plugs, T1R header, Megan test pipe, and Spoon Sports catback... Still had some tuning left to do on the ignition side of things but the car was lively enough for my liking at that time before I went with boost. If you'd like to see details regarding that, feel free to check out my thread linked in my signature below.
Most efficient bang for buck in terms of overall FUN wise though... Address any bushing and/or ball joint related wear items first like mentioned then find some lighter wheels (15x7 Advanti Storm S1s for example... 'Po' man's RPF1' I call them... $130 a wheel shipped @10.6 lbs. or Tire Rack Motorsport C1 if they're still available... $100 a wheel, 12.6 lbs each), a little bit wider and sticker tire (205/50R15s), put a Progress rear anti-roll bar on and decent springs and shocks (maybe even coilovers if you're up for it) then enjoy the car as the little fun momentum car it is.
Old Apr 4, 2019 | 03:29 AM
Baldwin Nguyen's Avatar
I own an '08 Sport AT and while I wouldn't consider myself too knowledgeable, I personally felt my bolt-ons made a difference for me. I have an axle back, CAI and Hondata (got it for a steal!) with a base map tune for the time being. It's definitely made a noticeable difference on the low end torque for me.
dekayfit
Oct 13, 2013 03:27 PM
kevbluedog
Dec 13, 2010 01:44 PM
kelly
Nov 17, 2008 08:46 PM
slip
May 9, 2008 06:02 PM
Brad_again
Mar 31, 2007 02:07 AM
