2009 Honda Fit Sport - No power, dashboard lights, etc.
Old May 19, 2019 | 07:56 PM
sk8disney's Avatar
Looking for some help. I have have a 2009 Honda Fit Sport and I just replaced the starter. Starter worked fine for two weeks and now the car is dead. I put the key into the ignition and the turned the key. Nothing works; its like I removed the battery from the car. I had the AAA tech come out to check the battery and alternator. Both check out good. The AAA disconnected the positive terminal from the battery and then connected his jump pack to it. Lights didn't come on at all. I had AAA tow it home so I could check the fuses and relays. All three fuses in the engine compartment are good and I verified the fuses in the dashboard but all looked good. I took it down to the mechanic, but he is unable to locate the problem also.
Any help would be great.
In advance, thank you.
Old Mar 25, 2021 | 02:33 PM
Mayasfit's Avatar
Same problem
hi!
I Hope you got your fit sorted!
i stumbled I. Your post- because the same thing has happened to me and I’m trying to sort it.
Did you discover the problem? Can you help - any ideas about what going on with my FIt?
Old Mar 25, 2021 | 05:16 PM
JohnHenry's Avatar
The positive battery terminal has a 100A fuse on it, start there.
Old Mar 25, 2021 | 05:25 PM
Mayasfit's Avatar
Thx!
thank you!
I’ ll start with fuses and see what happens!
thx m
Rikkie Her
May 19, 2019 05:46 PM
robertsc1966
36
Oct 19, 2018 01:56 PM
Marcosinthehondajazz
Jun 19, 2017 12:34 AM
paullahey
Mar 16, 2015 09:17 AM
Dayv
Apr 22, 2012 07:03 PM
