2010 Honda Fit Electrical Issue with Passenger Headlight/Running Light/Blinkers
Old Oct 29, 2019 | 04:38 PM
wavy4jc's Avatar
Hello, just had a weird situation happen with my front passenger side headlight/daylight/parking light/blinker. They ALL lights stopped working at the same time. ALL bulbs work (I put them in the drivers side sockets to check). The front right blinker (passenger side) blinks very fast (The drivers side blinker is normal). The rear passenger side blinker light DOES work and it blinks very fast also. There is NO power coming to the front passenger side light bulb sockets. I Could not find a fuse to correspond to any of the front passenger side lights. I assume that the blinker relay works because the drivers side blinker works fine.
Has anyone else has this issue happen to them? I would appreciate any help or advice that you could share. Thanks so much!!
Old Oct 29, 2019 | 05:08 PM
marmaladedad's Avatar
Are the wiring plugs/connectors fully seated?
Old Oct 29, 2019 | 05:18 PM
wavy4jc's Avatar
Yes. I have all the bulbs well seated in the sockets/connectors. None light up.
Old Oct 31, 2019 | 08:12 PM
xxryu139xx's Avatar
check the fuse for "small lights" iirc
whatthephil
Nov 5, 2017 07:08 PM
123sillyboy123
Jan 2, 2015 09:43 PM
gkitf16
Mar 26, 2012 01:19 AM
gkitf16
Mar 24, 2012 08:53 PM
GoMiddies
Apr 20, 2011 12:07 PM
