Morimoto xb headlight
Old Nov 5, 2019 | 02:25 PM
metal's Avatar
Question Morimoto xb headlight
I just installed the morimoto XB headlight for 17 fit and I'm having problems with the DRL fuse tap that is supplied. I added the fuse tap to "17" DRL fuse panel but the DRL doesn't turn off when the engine shuts off. Any suggestions, am I doing something wrong?
Old Nov 5, 2019 | 06:18 PM
GolNat's Avatar
So if the DRL stays on when the ignition is off the DRL is wired directly to power instead of a switched source.
That fuse tap probably supplies power to the DRL circuit/relay but not to the actual lights. The lights are most likely controlled via a relay. You need to tap the switched side of the relay not the powered (hot) side.
Will Andrews
Jan 24, 2019 02:28 PM
FitBiscuit
Sep 21, 2017 07:57 AM
j5ive
Canada Fit Forums & Clubs
18
Sep 16, 2014 01:52 PM
Orlandoech.com
Jul 2, 2010 01:35 PM
fit2bcrazed
Nov 30, 2007 03:43 PM
