Would someone please post a picture for me?
Old Dec 3, 2019 | 07:15 PM
BadAnimal's Avatar
Would someone please post a good closeup picture of their open under hood fuse box, 2015/2016 EX model?
I don't have a 7.5A fuse in the #17 slot, should there be?
Thank you!!
Old Dec 4, 2019 | 09:19 AM
marmaladedad's Avatar
Google-ing says that position should be for DRL. Hope that helps.
Old Dec 4, 2019 | 09:24 AM
BadAnimal's Avatar
Thanks for the reply, no it doesn't help. I have the manual.
I'm just wondering why I have no fuse in that location and if there should be.
Currently my tail lights do not come when I turn on my headlights and I need to get that fixed ASAP!!!
Old Dec 4, 2019 | 10:31 AM
Jazu's Avatar
When was the car last serviced (or did you borrow a fuse). I've not seen a missing fuse before unless you just service or bought the car.
Old Dec 4, 2019 | 10:38 AM
BadAnimal's Avatar
Bought the car almost two years ago. I don't know how long my problem has existed. But, on my Fit, there is no fuse in the #17 spot. I just wondered if others did.
Old Dec 4, 2019 | 10:52 AM
woof's Avatar
Why not just put a fuse in and see what happens.
Old Dec 4, 2019 | 11:13 AM
BadAnimal's Avatar
Could do that but at the bottom where the fuse goes, there is no connector. I assume there never was one?
Old Dec 4, 2019 | 12:17 PM
woof's Avatar
Quite possible. DRL was a requirement for the Canadian cars but not US. I don't know if Honda put it in the US cars anyways - many manufacturers did. If there was DRL there then it is possible that a previous owner pulled out the fuse and wiring because he didn't like DRL. I'm not sure why you're focused on this. DRL is for front lighting only - there is no DRL lighting in the rear (although that is about to change since the Canadian government is in the process of mandating rear DRL lighting). Your problem as I recall is a lack of regular rear lighting.
Old Dec 4, 2019 | 02:17 PM
2Rismo2's Avatar
Thank you!!
Here it is in my 2015 EX. I don't have a fuse in that location either. Tail lights work though.
seditious3
Jul 20, 2019 06:26 PM
hnickm
Nov 28, 2015 08:29 PM
eCity Fit
Oct 18, 2014 10:44 AM
Fat Ping Cat
Jul 5, 2008 12:34 AM
sLiVeRwOrM
May 13, 2006 11:02 AM
