Does the upper bearing need to be replaced when replacing struts?
Old Dec 11, 2019 | 05:52 PM
Fittoad's Avatar
I need to replace my struts. I've called around for quotes. Someone mentioned that their price included replacing the upper bearing. That made me question the prices I'd been given, and whether I need to replace these as a matter of course.
Thanks for your reponse.
Old Dec 11, 2019 | 06:49 PM
GolNat's Avatar
How many miles are on the original? If I was paying someone I might get them done. You are getting quotes on Monroe or KYB struts?
Old Dec 11, 2019 | 06:58 PM
Fittoad's Avatar
Struts
I don't know how many miles on the current set. I'm the fourth owner.
KYB.
Old Dec 11, 2019 | 07:51 PM
GolNat's Avatar
They most likely have been quoting the quick strut type since it's easier for them. How many miles on the car? Honda struts are good for 100k. Is the ride bouncy.
Old Dec 11, 2019 | 08:02 PM
Fittoad's Avatar
Struts
111k miles. I've had the Fit for about 10k miles, and it does seem a little loose at speed. I always chalked it up to being a small vehicle, but it could definitely be a suspension thing.
Thanks for all the responses.
Old Dec 12, 2019 | 11:29 AM
Rob H's Avatar
It's a cheap part, replace it. It's a wear item. If your car was brand new and you were just replacing the springs to lower it then I'd say it would be OK to reuse what's on there. Your car isn't new and has 100K+ of parts that you don't know the condition of.
Old Dec 12, 2019 | 01:23 PM
evilchargerfan's Avatar
Chilton mentions to replace nuts/bolts. I dont see any recommendation to replace bearing
Old Dec 12, 2019 | 01:24 PM
I think they do mention to "check" for deformation / weakness / damage / etc
Old Dec 13, 2019 | 07:17 AM
Flashesbuck's Avatar
I did my struts myself about a year ago. I bought the fully loaded ones, cheapest Rock Auto had and the they came with that top bushing. I would bet that all the shops are including the "Top Bearing" aka that upper rubber bushing. Even if they are not, it wont make a differance. The ones I took out of my car were fine, with 250K on them.
Eggie
Nov 27, 2018 01:19 AM
WR2008Base
Mar 24, 2018 11:27 AM
CrystalFiveMT
Aug 4, 2016 06:06 PM
Socialvegetable
Jun 10, 2014 09:19 PM
The Doge
May 27, 2011 12:11 PM
