No Air Going to Feet or Windshield
Old Feb 3, 2020 | 09:00 PM
AXfreak's Avatar
I recently acquired an 07 Fit sport and while driving it the other day I noticed that the heat was only coming out of the front vents regardless of the setting. I was getting zero air to the windshield and the feet.
It looks like whatever moves to change the air flow is stuck.
Video I took showing how little the actuator arm moves:
How can I fix this? Will it require changing the entire blower or heater core unit?
Old Feb 5, 2020 | 12:51 PM
98Silverado's Avatar
Guessing something has fallen in a vent and jammed the blend door. You could try pulling the pollen filer out and looking through that slot and see if you can see in to that section of the ducts. Other option is to drop out the blower motor and see what you can access through there. You could pop the center vent(s) and see if you put an endoscope down in there and see anything from that direction. https://www.fitfreak.net/forums/fit-...-ac-vents.html
Old Feb 6, 2020 | 08:54 AM
AXfreak's Avatar
Ahh, didn't think of that. I will check this weekend using my friends scope. Thanks for the help!
TommyMadison
Nov 23, 2015 08:02 PM
TommyMadison
Oct 13, 2014 12:25 AM
Vince_TB
Jul 25, 2011 12:25 PM
willmax11
Canada Fit Forums & Clubs
Jan 12, 2009 04:13 PM
sLiVeRwOrM
Jul 8, 2006 03:40 AM
