Sponsored by:
Sponsored by: CARiD
Wk motor sport short shifter for GK fit?
Old Feb 28, 2020 | 02:06 AM
RD36's Avatar
Your thoughts?
Not cheap it's 430 a pop. I have the acuity bushing already. Not satisfied with the result.
Old Feb 28, 2020 | 07:15 AM
bill bosco's Avatar
i had a short shifter from neuspeed in my '02 SI , worked as advertised but was notchy , which got more so as the car aged ( had it for 16 years ) finally took it off , much smoother , wouldn't do it again .also , note that you're just shortening the throw , it won't actually let you shift quicker .that's not good the transmission
Old Feb 28, 2020 | 01:31 PM
RD36's Avatar
I HATE the shifter feel on this car. Worst I ever had in a manual. Will Royal Purple smooth it out?
Old Feb 29, 2020 | 03:31 PM
RD36's Avatar
Apparently there's a clutch delay valve that's taking the fun out of manual tranny. Is this the part near the fire wall or is it the one on the gear box?
Old Feb 29, 2020 | 05:12 PM
bill bosco's Avatar
that's not delay , it looks like a slave cylinder for the clutch pedal , it's hydraulic , it's a good shifting tranny but not set up to be the fastest , you can't really change that .
what you could do though , is switch to a heavier weighted shift knob . the extra weight helps smooth out the action going through the gates especially finding first ,
which can be a little notchy . i did that on mine , the stock knob is pretty lite , it helped alot
Old Feb 29, 2020 | 06:14 PM
RD36's Avatar
Might get me the acuity gear knob then. I got the pedal spacer, amazing stuff. Also the bushing not bad. But hope the gear knob makes it more OK'ish.
StakerFit07
48
Nov 16, 2020 09:27 PM
Fit2Bsquare$
Feb 18, 2020 06:24 PM
onetwothree
Sep 11, 2015 10:01 PM
cptjon
May 20, 2015 07:32 PM
HarWeevKllr
Oct 6, 2014 01:13 PM
