LED Reverse Light Flicker: Gen 3 Fit EX
Old Nov 27, 2020 | 07:35 PM
mdude's Avatar
LED Installaion, DRL & Reverse Light Flicker: Gen 3 Fit EX
Hi, new to Fit and this forum. Got a brand new 2020 EX auto.
I switched to LED reverse using this brand:
Amazon Amazon
Every time reverse is engaged, the light will blink a few times and then stay on (so long as transmission is in R).
According to the product description (which admitted I didn't read carefully until after installation) this is normal. Quote:
  • This bulb will strobe flash at the beginning of braking model and then keep solid light, which is legal blinking for braking stop safety alert, much easier noticed while braking and much safer for braking.
Is that any reason to worry? Should I change to a non-blinking type bulb?
Thanks in advance for any advice.
Old Nov 27, 2020 | 08:04 PM
Ben Pierce's Avatar
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I would have recommend a reputable brand such as Sylvania. I don't know how long that chinese led bulb will last.
Old Nov 27, 2020 | 08:14 PM
mdude's Avatar
Thanks, Ben.
I'll see how long this last. Will report back in a few months...
I also ordered H4 LED plus Canbus decoder and will see how those turn out.
Old Nov 28, 2020 | 08:38 AM
2Rismo2's Avatar
Ask yourself for how long you're in reverse on a daily basis. It should last a while...
Old Dec 3, 2020 | 06:42 PM
mdude's Avatar
Update:
Installed LED headlamp. Observations:
  • When installed w/o canbus decoder, there is DRL flicker but only when viewed from a camera lense; not visible to the naked eye. The DRL brightness is identical, far as I can tell (meaning quite dim), just like the factory halogens.
  • When installed w/ canbus decoder, the DRL flicker stops but it looks like the headlamps are on high beam all the time (headlight switched turned to off, meaning DRL mode runs on default). See pic below:
  • When headlamp is actually turned on, it looks 'normal'. See pic below:
  • Happy to see that neither mode blinds oncoming drivers, which was my main concern installing LEDs on reflectors. I usually set the headlight on 'Auto' so that the so-called high beam only comes on during the day.
  • I might decide to take out the canbus decoder and simply have DRL flicker (again invisible to naked eye). From what I read, flickering LEDs do no harm.
mrdavis
Aug 6, 2019 12:09 PM
Bob Levine
Jan 1, 2017 06:57 PM
mmitsch
Nov 5, 2014 08:52 AM
Jspec5
Mar 11, 2009 09:58 PM
Rubba Burna
Oct 12, 2008 09:09 PM
