Rough idle continues after valve adjustment
Old Dec 1, 2020 | 07:45 PM
over8gb's Avatar
Question Rough idle continues after valve adjustment
Hi friends, I'm back with a new problem
2008 Sport automatic with 58k miles (yep, very low). This week in Chicago, temps dropped into the 30s, and the Fit started idling rough - little jolts / stumbles. It does this on cold start and doesn't improve when warm. Once moving the engine seems perfect - just an issue with idle. I bought the car this summer and this is the first time this has happened.
I've poked around this forum a lot, and based on these symptoms and mileage, I had the valve adjusted today. Both intake and exhaust were significantly out of spec (my mechanic was pretty surprised by how far out they were).
The engine audibly sounds better and feels great when driving, but the idle is exactly the same as before - no change.
I had the plugs replaced when I first bought the car (Denso Iridium).
Where should I look next?
Thanks!!
Old Dec 3, 2020 | 10:10 PM
doctor J's Avatar
Ignition coils and recheck the plugs (make sure that they are tight)
If this will not solve the problem unbolt EGR valve (but leave if connected) and cover the flange with metal piece
Old Dec 8, 2020 | 03:02 PM
Jared592's Avatar
Seconding the ignition coils. Don't cheap out, get the Hitachis (they're the OEM, but you can get them cheaper than they'd be at the Honda dealer).
Old Dec 13, 2020 | 12:34 AM
over8gb's Avatar
I changed all four coils yesterday (Hitachi), engine is running perfectly now. Thanks!!
melissaland
Jul 16, 2022 06:51 PM
moten33
Feb 9, 2019 08:34 AM
Sandra Dorothy
Dec 28, 2018 09:28 PM
canbac21
Jan 18, 2016 05:50 PM
sesa422
Mar 19, 2013 10:11 AM
