B-Spec racers
Old Dec 29, 2020 | 06:27 PM
Jllsatx's Avatar
B-Spec racers
Any B-Spec racers on this forum? I started my build today.
Old Dec 31, 2020 | 06:38 PM
Z062FIT's Avatar
B-Spec
Not yet, but definitely curious on how to spec the car? Can you share regulations and references as you find them? The kid in Texas won SCCA b-spec in a 2017 fit last year and I'd like to start a build but may be too far modded at this point...
Old Jan 1, 2021 | 01:04 PM
Jllsatx's Avatar
Go to SCCA.com. Select programs and then select Road Racing. You can find the rules link on the left hand side of the page if you scroll down.
Old Jan 9, 2021 | 11:02 PM
Z062FIT's Avatar
B spec
30mm restrictor plate? No thanks. Good luck to you!
Old Aug 22, 2022 | 03:32 PM
dOwntOwn's Avatar
they only allow us a 52mm (choked us down from 68mm) restrictor plate in the C6 vette in T1 class, and they make us weigh in at 3200 lbs. 😱
they let the c5 guys have a 75mm🫤
But. It’ll be interesting to build up my fit as a b spec racer.
I toldt myself that I’d consider putting the Fitty on the track if it hit 100kmiles.
I’m at 82,000 now
Cage ordered. Bilsteins are already In the garage.
by next spring I should have all the parts gathered along w the 100k marker rolled over.
Old Aug 22, 2022 | 03:37 PM
Z062FIT's Avatar
Cage ordered?
Cojones! Which one did you get?
Radi
Jul 9, 2017 04:33 AM
Funkster
Jul 6, 2011 12:10 PM
Gbaby2089
May 27, 2009 09:46 PM
pizzicato
Oct 16, 2008 12:36 PM
molliweide
Apr 18, 2006 05:56 PM
