Head lights upgrades
Old Jan 14, 2021 | 10:52 AM
onevw's Avatar
Hello:
So, by looking at the comments no led/hid headlight bulbs will work 100% correctly in a 2013 fit?
Is this correct?
Rick
Old Jan 14, 2021 | 12:37 PM
NWCH's Avatar
I have full LED's in my second gen. No issues at all.
Old Jan 14, 2021 | 12:44 PM
onevw's Avatar
Do you know what brand and model you have installed.
Thanks
Rick
Old Jan 14, 2021 | 03:27 PM
GAFIT's Avatar
It's a complicated issue. Obviously you can physically put HID or LED bulbs in a halogen housing, but getting the beam patter correct is NOT easy. You need the bulb to emit light in the same direction as the original halogen bulb so that it hits the reflector in the same locations.
We put HID's in ours way back when and it was a disaster. Put out a ton of light, but blinded other drivers.
However, there are now LED's that are more patterned and could possibly work for both you and others. Here's a good article on the subject - https://www.gizmodo.com.au/2020/03/h...ind-everybody/
Sorry that I don't have an answer as to which bulb would work best for your GE. If you give the swap a try, I suggest only installing one bulb first and compare sides to make sure that the LED bulb is projecting light the same as the halogen bulb.
Old Jan 14, 2021 | 08:20 PM
De36's Avatar
Get 3000k HID Fogs & 5000k HID High Beams. And aim them high, Faraz Hussain loves people who upgrade their lighting.
Old Jan 14, 2021 | 08:23 PM
De36's Avatar
But seriously, aftermarket HID kits are a pain. I had to replace mine three times. Finally I went back to the OEM bulbs. If you find a kit that works please be sure to share with us.
Old Jan 14, 2021 | 08:31 PM
GAFIT's Avatar
Hilarious!
We had the same issue with the same outcome.
Put Sylvania SilverStar Ultra's in it for now. Next step will be a real retrofit from 818 Retrofits. That's the only truly perfect solution.
Old Jan 16, 2021 | 12:18 AM
ArtJDM's Avatar
Philips makes a set of 9003 LEDs. They seem to have a good handle on headlights.
https://www.powerbulbs.com/us/produc...xoCTgEQAvD_BwE
Old Jan 16, 2021 | 12:22 PM
Odie's Avatar
Sylvania Xtra Vision . Bright white to help with distinguishing objects ( deer , etc. ) at night . $19.99 at Walmart . Last for 2 to 3 years . Maybe 4 .
Old Jan 19, 2021 | 03:26 PM
sdmieth1's Avatar
I have a fill HID system in my GE Fit. Just pulled the lens off the headlights and put a projector in there. Provides much clearer light with an awesome pattern.
Old Jan 22, 2021 | 01:45 AM
Can_It_Fit's Avatar
+1
The difference with an actual retrofit will be better than any LED/HID drop in. What projectors did you end up using and did you take pics of your install?
jazzman
Jun 12, 2020 01:09 PM
DrSaw
21
Jan 4, 2020 01:15 PM
der Mond
Jan 16, 2017 05:10 PM
MrFrosty
California - Bay Area Community
Nov 21, 2013 04:12 PM
MrUrban
Arkansas Community
Oct 12, 2009 03:50 PM
