Blew the Clutch and Snapped an Axle!
Old Mar 25, 2021 | 08:57 AM
punx45's Avatar
Blew the Transmission and Snapped an Axle!
update edit: so it was actually the transmission! See later posts for details.
I recently blew the clutch on my '10 Fit, and snapped the axle in the process.
The clutch had been acting up. Scrapey noises, and something rattling around occasionally that stalled it out once or twice. But for some dumb reason I kept driving it. Well, while getting going in 1st from a stop light, in the middle of an intersection, suddenly: SLAM! The wheels lock up and tires squeal. Then it stalls out, and I roll it to the side. I tried starting it back up to see if I could limp it all the way out of the intersection. no go.
I haven't had time to do a tear down to see all what happened inside, but heres a nice picture of the outside carnage!
Old Mar 25, 2021 | 10:38 AM
Jared592's Avatar
Regardless of the clutch situation, the axle shouldn't have snapped like that. Honda recently announced a recall on the axles on a variety of vehicles (including yours) for inadequate corrosion protection:
https://www.consumerreports.org/car-...aft-rust-risk/
Old Mar 25, 2021 | 11:00 AM
oldyeller's Avatar
Unless they're aftermarket axles
Old Mar 25, 2021 | 12:08 PM
punx45's Avatar
I've owned the fit since 2012, bought it at ~25k miles. I'm fairly certain they are the original axles.
unfortunately, won't really be worthwhile to tow it to a dealer for the fix, when I will be doing the rest myself anyway.
Old Mar 25, 2021 | 05:52 PM
steve37's Avatar
The wheels locked-up??
And squeal??
Old Mar 26, 2021 | 08:19 AM
punx45's Avatar
And squeal??
yes, my theory is the clutch disc broke down and jammed up the shaft, locking up the wheels and stalling out the engine. I won't know for sure until I tear it down, but I have a few other projects in line first
Old Mar 26, 2021 | 01:18 PM
steve37's Avatar
I understand now. Keep us posted on how it works out.
Old Mar 27, 2021 | 10:08 AM
RyanW's Avatar
The cost of towing for 1 or 2 new, OEM axles isn't worth it to you? A tow will be the same as 2 trash aftermarket axles. I'd do whatever I could to get free OEM axles out of it.
Old Nov 5, 2021 | 02:36 PM
punx45's Avatar
hey long time later, finally got everything sorted out. it was much, much worse. heated up some bearings and locked the transmission up
check. your. fluid. levels.
Here's some grooves in the inner surface of a gear from the bearing.
That's what's left of the bearing. Some cutting had to be done, the gear was stuck on, but the bearing was trashed.
Old Nov 5, 2021 | 05:36 PM
mobby_6kl's Avatar
Oh wow, an impressive amount of damage. So do you think the transmission was the cause of this? Or did the clutch blow up first?
Old Nov 5, 2021 | 05:57 PM
punx45's Avatar
oh yeah I forgot to mention that. the transmission was definitely at fault. It was basically permanently fused in 4th gear.
The clutch was in fantastic shape. There were some gouges in the springs that seemed to line up with gouges in the flywheel bolts. I’m assuming that was a result of the failure, so I replaced that too just in case.
Old Nov 5, 2021 | 10:06 PM
Pyts's Avatar
Pictures like that keep me going with preventative maint. You got it back up and running today? Did a trans swap?
Old Nov 6, 2021 | 07:43 AM
punx45's Avatar
yup junkyard trans and new clutch kit. Took a while to get around to it since I have a truck also, and wife and my priorities took a while to align 😂
Old Nov 6, 2021 | 02:23 PM
Mister Coffee's Avatar
@punx45 Nice work, punx. So, your diagnosis of the failure was that your MT fluid level got low, or completely disappeared, and that lead to the transmission failure?
Old Nov 6, 2021 | 05:16 PM
punx45's Avatar
you got it!
Bounce
Jul 15, 2017 07:28 PM
radfit
May 11, 2012 11:54 PM
Romulus
Sep 24, 2010 10:45 AM
shy34
Aug 31, 2009 03:16 PM
YeeFit
May 9, 2009 09:34 PM
