Checking automatic tranny fluid
Old Apr 2, 2021 | 12:35 AM
Jadeon15's Avatar
Does anyone know if it really matters whether I check the tranny fluid while it's really cold outside?
Old Apr 2, 2021 | 10:18 AM
fit09's Avatar
You want to drive the car until it reaches operating temperature first, then park car on a level surface, turn engine off and within 90 seconds check the fluid level. Outside temperature does not matter, just follow these steps. Same thing is stated in your owners manual.
Old Apr 3, 2021 | 11:07 AM
Alco RS-1's Avatar
The owner's manual reads that the engine should be left to run until the cooling fan starts. This assures that the tranny fluid is at the proper temperature. Only then do you shut the engine off to check the level. Be sure to wipe the dipstick before checking the level. It foams a bit around the dipstick, so gives a false indication if not wiped down beforehand.
dvoisawesome
Dec 12, 2017 02:43 PM
kaede1337
Jul 31, 2016 05:22 PM
Odie
Jul 22, 2014 07:24 PM
KTfit
Jul 24, 2012 07:16 PM
gmac
Mar 2, 2012 01:21 PM
