Steering Wheel Controls and Lanewatch Adapters '16 GK5
Old Apr 3, 2021 | 04:17 PM
Action Jackson's Avatar
Steering Wheel Controllers/Adapters with aftermarket head unit
I've used 3 of the current controllers/adapters on the market with my 2016 with my current Kenwood headunit (DNX995S). The Axxess ASWC-01 with A
xxess HDCC-02 Wiring Interface, PAC RP4-HD11 and iDatalink Maestro RR Interface Module with iDatalink HRN-RR-HO2 Factory Integration Adapter.
I had posted something about the first 2 here: https://www.fitfreak.net/forums/3rd-...aswc-01-a.html
Here are the results:
Axxess ASWC-01 with Axxess HDCC-02 Wiring Interface
PROS:
Volume and source buttons "work"
"Allows" Reverse and Lanewatch cameras Reverse view is a clear picture.
ACC mode lets you use your head unit.
When car is running and you turn off IGN to ACC mode, it allows the head unit to be used.
CONS:
Occasionally and often when volume up is pushed. It changes the source. Extremely annoying forcing me to hit source multiple times to put be back to the original source. Volume up then might not work forcing me to use the volume button on head unit.
Reverse camera defaults to wide angle (I do not mind this at all) with no option of picking any other view.
If you want reverse camera to have backup lines, then those same backup lines shows up in the lanewatch camera view!
Uses the factory signals to feed camera views into a single camera input on headunit (mine has both rear and front inputs). Reversing is no issue. However when lanewatch is active, the "picture" quality is distorted with interference and the picture shifts focus (like an antenna tv from the 80's) making lanewatch pretty much useless while driving. Stationary the image is great.
When hazard lights are activated, it activates lanewatch. This makes trying to park on the side of the road and using the Kenwood GPS absolutely useless.
Phone controls are absolutely useless, as is the other buttons such as menu and file. Only the volume and source buttons are used.
Cannot program the buttons to do anything else even though it is an available feature.
The next/back buttons do not skip folders, rather only fast forwards/backwards.
In ACC mode, you can use your headunit. The moment you select IGN, the head unit always shuts down and restarts up again.
Remedies:
Contacted Axxess tech support as well as Crutchfield tech support. Could not program any other buttons so unit was exchanged. The 2nd unit did not produce any camera image until Axxess told me to cut and reverse the camera input wires on their interface. I've spliced into OEM harnesses with no ability to use any of the phone control buttons.
Conclusion:
Maybe it was too early in the product life. Had to keep this unit in order to use the steering wheel controls (somewhat). Used this for several years with great frustration.
PAC RP4-HD11
PROS:
3 phone control buttons register. Answer and voice control works
Interfaces with Axxess HDCC-02 Wiring Interface to retain reverse and lanewatch cameras
Regular controls (volume/source) works
Lanewatch button works
CONS:
Hangup doesn't work
Headunit would stay on constantly after keys removed from ignition
At the time, has no reverse/lanewatch camera interface so must use the Axxess system.
Remedies:
Contacted PAC tech support to troubleshoot to no avail. Exchanged for a new unit with the exact same outcome after troubleshooting as well. Then the replacement unit refused to work with volume/source buttons after.
Conclusion:
Maybe it was too early in the product life. Tried using this interface after having the Axxess unit. Obviously never had this installed for long for any driving (head unit stays on!). So I've never used this for any length of time at all.
PROS:
All steering wheel buttons work are programmable with dual functions available. You end up with more features than OEM (ie. with a long hold of a button, I can mute/or pause the music from USB).
ACC/IGN function independently. Anytime you are in ACC mode, your head unit is perfectly usable. When you go from ACC to IGN, your head unit does not restart. It continues to stay on for some time. Can't figure out the exact time.
Retain ACC mode can be set for a few seconds to 15 mins. So when you turn off vehicle, the headunit will stay on based on the time you set, or turn off as normal
Reverse and Lanewatch function like OEM. Lanewatch had OEM lines. Reverse allows you to pick the 3 OEM views. The reverse lines are fully adjustable. Uses steering wheel vector lines so that when you steer in reverse, the entire lines do not shift, rather the car's size lines stay stationary, but steering vector lines shows up. It takes a little getting use to. Reverse and lanewatch use the rear and front camera inputs on my headunit.
Show's car voltage without OBD interface.
Hazard light does not activate lanewatch!
If for some reason your cameras end up not showing up, select "reset" in the Maestro options and it will reset it to the way you had it originally programmed.
CONS:
Ummmm… It's expensive and works so you get what you pay for?
Must know your head unit's serial number for interface to work (open car up, get serial number, go back to laptop to configure interface, then install).
OBDII port interface might not work. Have not tried to switch the 2 pickup wires to obtain desired functionality.
Programming "Navigation" button does not return me to my head unit's navigation screen, so this might be for OEM navigation.
When in reversing into a spot, make sure that you have your right turn signal on first, then shift into reverse. That way, the reverse camera overrides the lanewatch.
Remedies:
Not able to use "Climate" feature, might be available for models with automatic climate control which my car does not have.
Not able to use OBDII interface to use tire monitoring system... but Canadian models do not have TPMS. Will figure this out later to see if this unit uses ABS and speed sensors to figure out tire pressure.
Not able to use OBDII interface to use "track pack" gauges. Will have to figure out if interface is geared for USDM models. Honestly I don't really care if the interface doesn't work. Will have to work on this later.
Conclusion:
Works right off the bat. Just get this. Please check with idatalink's website for compatibility.
Old Dec 28, 2021 | 03:25 PM
amcraw16's Avatar
I know it has been a while, I just want to thank you for taking the time to document these. Looking at buying a 2015 fit, but I NEED to know an aftermarket HU with carplay will integrate with the rest of the car before I pull the trigger. Not a lot of information out there.
Do you lose any functionality like car settings that would ordinarily be changed in the OEM radio?
Old Dec 29, 2021 | 01:32 AM
Thanks for your compliment!
I haven't had my OEM unit for many years and I don't miss it. I set the clock with the odometer/trip switch.
Other than that, I don't miss using any of the OEM stuff via MID, which is what I think the OEM unit interfaced with.
If there is a feature that you want to retain, let me know and I'll see if I can still access it, but that may be specific to the head unit you're interested in.
Old Oct 28, 2024 | 02:12 PM
jgills240's Avatar
Question More Qs
@Action Jackson Thanks for posting this! There's very little 'recent' data out there on how these Android/aftermarket radios interface with the OEM hardware.
One more question, did you have to modify the harnesses of any that you used (other than the bottom one that apparently 'just works')? I've come across pinout descriptions for one of the connectors on the OEM head unit, but no others, so haven't been able to identify the lanewatch vs backup video wires, etc...
Thanks again!
Old Oct 30, 2024 | 10:46 PM
It's been awhile since my Fit was totalled. The iDatalink Maestro worked perfectly with my '16 Fit.
When I transfered my entire audio system into my '15 Accord, I had to figure out how to activate my reverse camera so a minor splicing was involved. I don't have reverse vector lines, or lanewatch with the turn signal.
There is no guarantee that even a good and reputable manufacturer can be 100% fully compatible.
Old Oct 30, 2024 | 11:21 PM
jgills240's Avatar
Full Pinout Diagrams Found
Thanks for being an active poster!
My wife actually found this cross thread with the full pinouts for the Infotainment head unit: https://www.fitfreak.net/forums/3rd-...onnectors.html
So I was able to get my LaneWatch sorted out, but thanks again, and hope you're happy with your Accord!
I created a PDF of the images in the other thread for easier use, reposted here.
carlyee
May 28, 2025 12:27 AM
changerrs
Apr 19, 2021 12:33 PM
Action Jackson
Apr 25, 2020 02:04 PM
Jasonvicktory86
Oct 4, 2019 11:49 AM
changerrs
2nd Generation GE8 Specific Fit I.C.E. Sub-Forum
Aug 13, 2019 02:27 PM
