Replacement for missing Aux Jack piece
Old Jun 8, 2021 | 11:17 PM
Torchiest's Avatar
Hello! I just purchased a 2010 Fit, and I didn't realize at the time that the 3.5mm auxiliary jack was actually partially damaged/missing. It seems like the little cap piece is gone. When I tried to plug in a cord, it kind of works, but it's loose and the sound cuts in and out when it wiggles around. I've been looking around and can't seem to find just that piece. It seems like there are replacements available for the aux jack in the layout with the Navigation add-on, but not for this layout with the jack in the control panel. Does anyone have any ideas on how to repair this? Is it possible to get just that cover/cap piece?
Cover that I don't have
Old Jun 14, 2021 | 07:11 PM
Pyts's Avatar
I suspect that pursuit of that cap will lead you to the dealership.
As for the aux port, a stereo shop could help you, otherwise you'd need to get into that dash cover and check the wire. if damaged, cut out the current jack and solder in a new one. Better yet, upgrade the stereo
Old Jun 15, 2021 | 02:14 AM
56chevydan's Avatar
I had a pretty sharp parts guy that I know, at my local Honda dealership, check into this same issue for me about 6 mos ago. After a few days of looking into it, he found it is not a serviceable part for our radios. I also found that some auxilary cables come slightly undersize and don't fit the auxilary port tightly.This loose connection can also cause the cutting in and out for the sound.
The only way I know of to get a working auxilary plug with a cover is to buy a radio out of a donor car where the owner can verify the auxilary port works on that radio.
Old Jun 15, 2021 | 06:58 PM
dhuang's Avatar
Mine was intact for awhile but eventually the UV rays made the rubber crack.
When I tried to remove it, it disintegrated and crumbled in my hands.
Old Jun 16, 2021 | 08:30 PM
eulogy's Avatar
Here is the backside of the aux plug. (Behind that square raised protrusion) Nothing servicable. Unless u want to de-solder stuff from the board.
Old Jun 17, 2021 | 03:34 PM
steve37's Avatar
If you are good at soldering...I have the one you need. It's off my 2010 Fit.
I de-soldered it and it's in perfect condition. There is no cover with this one...never had one.
PM me and I'll send it to you for $5
Joed
Oct 16, 2020 01:07 AM
Jacob Faria
Jan 29, 2017 09:01 PM
ydna
Nov 1, 2011 08:19 PM
李克勤
May 3, 2006 08:59 PM
shipwrek
Mar 31, 2006 12:17 PM
