HELP! Radio and Dome Light doesn't work
Old Dec 17, 2006 | 04:13 PM
heymikesays's Avatar
Problem solved! Ahh thanks for looking anyway.
Guess I could show the map lights which caused the mess to begin with
Old Dec 17, 2006 | 07:26 PM
spider2k's Avatar
lawlz i have my broadway from my s2k in mine too.
Old Dec 17, 2006 | 07:33 PM
sillypuddy's Avatar
Someone that Posts too much
what car are those maps lights from?
-joe
Old Dec 17, 2006 | 08:41 PM
-joe
2006-07 Honda Civic
Old Dec 17, 2006 | 08:54 PM
Spule 4's Avatar
Any brackets, or just a hole in the headliner? Looks sharp!
Old Dec 20, 2006 | 09:54 AM
so far it mounts without a bracket just fine. no looseness and/or movement when pushing the lights on. im debating whether or not fabricating a bracket is even necessary. I did use the factory foam to place in areas where the roof might give way if the unit is used and its pretty sturdy.
Old Dec 27, 2006 | 11:49 PM
sorrikim's Avatar
Hey! How was the wiring? was it easy to connect the wire? and where did you connect it to?
Old Dec 28, 2006 | 02:00 AM
I hooked up the power to the red/white wire of the dome light, ground to rear view mirror (search other posts)
The unit itself im still trying to locate a wiring diagram as I am having difficulty getting the passenger side light to work (driver side works fine) Otherwise, it doesn't go off when the dome light does and one light works so im one light away from this being completed.
Old May 7, 2012 | 12:18 PM
supremeXorio's Avatar
What was wrong? My stereo ,map light and trunk light as well as my parking lights all don't work
Old May 7, 2012 | 02:25 PM
Black3sr's Avatar
Someone stole your battery.
Old May 8, 2012 | 12:41 AM
Talking
Ya some troll had it. All fixed now.
radioarno
Aug 31, 2023 10:41 AM
jl0r
109
Jan 6, 2019 07:52 AM
wdb
May 28, 2014 11:45 AM
Roger's Fit
Oct 31, 2009 02:23 AM
Bigkatdaddy
Oct 14, 2009 01:02 AM
