Bad cat
Old Jul 17, 2021 | 06:33 PM
Cwong's Avatar
Bad cat
Hello
I am sure I have a bad car (car surges with out pressing on gas, code, overheats if I am not on highway). The bolts are rusted on like hell (220k) so I was thinking about popping from autozone with connect exhaust clamps and pipe and o2 spacer what are your thoughts? I will only cut out the cat ( maybe 7 inches?)
Old Jul 19, 2021 | 03:20 AM
ikutoisahobo's Avatar
What are the codes that you're getting?
If it is the cat then do it right. Replace the cat. Use lots of penetrating fluid on the bolts the night before. If you can get an impact with some adapters on it, do that. Or have a shop do it and let them deal with the bolts.
Your idea screams exhaust leaks and hackjobbery
Old Jul 21, 2021 | 04:33 AM
Cwong's Avatar
Lol lol I am going hook it up to the impact wrench after a long drive and see if it helps. This is a a to b car so less money I put the better.
kurobaxkaito
Mar 20, 2018 04:01 PM
Santiad
Apr 2, 2014 10:24 PM
Maty J
Aug 31, 2013 02:06 AM
GROC80
Apr 30, 2008 09:49 PM
dudley
Jan 29, 2008 10:38 AM
