Help identify these wheels
A little while back I picked up a set of used wheels for cheap and hoped to use them for winter. Of couse, the seller lied about sizing and specs in the messages we exchanged, and I had a friend pick them up for me (the seller was located close to my friend, several hours away from me). Anyway, long story short, they don't fit my 2018 Fit.
From the measurements I have taken, here's what I have come up with:
15x6 dimensions
4x114.3 bolt pattern
Centre bore seems to be 63 or 64mm (hard to get an exact measurement)
I have measured offset to be ~ +55 (also hard to get an exact measurement).
I'm really just trying to determine what they will fit. I suspect they are not even OEM wheels. Probably aftermarket. No identification markings on them anywhere.
Has anyone ever seen a wheel like these? Do you know which make/model they might be from? Appreciate any help. Thanks.
Does the color of the center cap match the wheel color? It's a bit difficult to tell on my monitor. If they were OEM I would expect some information on the inside spokes of the rim (e.g., wheel dimensions).
Off the top of my head, I thought that 4x114.3 mm (or 4 x 4.5 inch) was an odd bolt pattern, but apparently not.
https://sizemywheels.com/lz-pcd/4-114.3
Lots of older Hondas (and other Japanese manufacturers) on the list. Maybe an old Accord or Prelude wheel? Maybe something totally random that the seller put generic Honda center caps on.
That's fantastic. Thank you.
_nifty_
Mar 15, 2019 11:27 PM
