07 fit only starts with starter fluid. Dies unless it gets up to temp
Old Feb 19, 2024 | 01:39 PM
rmez27's Avatar
Hey, I've got an 07 fit that turns over but wont start unless I spray starter fluid in the intake and then it dies unless I leave my foot on the pedal long enough to get it up to temp. Then it runs normal. I thought this might mean something to do with the fuel system but it only has 75000 miles and I read that the fuel pump and filter are generally thought to be good for the life of the car. Also a pain to replace. Any thoughts as to what might be the issue? in the weeks prior to this problem it did sputter a little bit as if it wanted to stall when it was cold. Could it be weak spark?
Thanks
-Rand
Old Feb 20, 2024 | 01:09 PM
rmez27's Avatar
One thing I might add and hopefully someone can help, is that the cold temperature light would always come on back when the car would start and the hot temperature light came on a few times while driving prior to the starting issue. I checked and the cooling system was fine. Is it possible that a faulty temperature sensor of some kind would cause the car to not get enough fuel at start up? This is the cars first winter in a northern climate after spending it's life in California. hoping to have some idea of what might be going on before I throw a new fuel pump at it.
steve37
Sep 22, 2023 10:14 AM
techburgher
Mar 3, 2023 12:03 AM
Phillip S. Chrin
May 24, 2017 12:41 PM
Santiad
Dec 30, 2016 12:31 AM
DCTepper
Nov 22, 2013 07:41 AM
