Oil in Intake
Old Oct 13, 2024 | 08:15 AM
dyd069's Avatar
Oil in Intake
Hi all. I did my VTC spring yesterday and when I went to put my intake back on I noticed engine oil inside it. I'm new to Fit's but would this point to a bad PCV valve? The engine seems very healthy. Plugs were nice and dry. 70,000 Km on it and it was over maintained by previous owner.
Thanks
Old Oct 14, 2024 | 05:18 AM
3rdGenOwner's Avatar
I noticed the same when doing a valve adjustment. Replaced my PCV (cheap) and cleaned out the intake, but I'm still seeing oil in the intake. I think the PCV is fine, but the EGR system is really oily because of the high pressure L15B "Earth Dreams" engine.
Side note, since the intake was so oily, I decided to clean my intake valves with Liqui Moly and saw an improvement of 25 mpg -> 37 mpg
Thanks
Old Oct 14, 2024 | 08:49 AM
dyd069's Avatar
Hey, thanks 3rdGenOwner. So I should research the EGR system, or just leave it as-is? It runs like a swiss watch.
Old Oct 14, 2024 | 11:54 PM
if your happy with it, leave it be. It will just gunk up after a while. Seems like you have the skills to clean it whenever you start seeing mpg loss
You can install a catch can, but that usually leads to more headaches.
Old Oct 15, 2024 | 09:51 AM
dyd069's Avatar
Thanks again 3rdGenOwner. After checking the oil, it looks overfilled quite a bit from dumb dealer I bought the car from. Thinking that might be contributing to it.
BigSpark
Oct 17, 2019 10:47 PM
DrKelso
15
Nov 2, 2009 10:06 PM
YeeFit
13
Jan 18, 2009 09:28 PM
MemphisFit
Jul 1, 2008 10:14 AM
Spule 4
Jul 1, 2007 08:33 AM
