Light bar wiring GE8
Old Jul 17, 2025 | 12:10 AM
FreakyFiter's Avatar
I'm making this post because I wasn't able to find the information when I was wiring my new light bar. For reference I installed it behind the lower grill portion and needed a way to get the switch through the fire wall. I ended up routing the wire through the upper wheel well on the driver side and pushing the wire through a grommet next to the hood release cable. It basically follows the same path as the hood release cable but enters the cab through a different hole. If you watch a video on how to replace your hood release cable you will see the same hole covered by a small plastic grommet.
Hope this helps.
Black3sr
Jul 12, 2019 09:46 AM
benmaggoswd1
Mar 19, 2018 10:20 AM
CrystalFiveMT
Oct 2, 2014 05:09 PM
Black3sr
Nov 17, 2011 07:40 AM
CrystalFiveMT
Dec 25, 2009 01:48 PM
