Advice on aftermarket Catalytic Converters?
I've got an 09 Fit that started throwing a P420 several years back doing local trips in cold weather. A good highway run tended to clear it for a while. Not this year.
I'm in a state that does emissions checks and so I'm looking at replacements. I'm looking at parts from Rock Auto, just wondered if anyone had suggestions for other sources a little less $$.
Thanks
Jim
Thanks
Jim
It is very unusual that a catalytic converter goes bad if there is no mechanical damage or use of leaded fuel. An your car is only 17 years. I would thoroughly check other possible reasons for the code first. Bad sensors are much more likely than bad cat.
Depends more on mileage than age, doesn't it? Especially if you've been running rich for a long time. Cats can only absorb so much before they go bad. And I've seen cats go bad at even 100K miles.
If it runs rich, it shouldn't pass the emission test.
I don't know if it possible to test a lambda (O2) sensor, but even replacing it is much easier and less costly than replacing the cat. Therefore I'd try that first. Actually I think there are sensors both pre and post the cat. There might be some temperature sensors, which would also cause to that code when not working properly.
This right here. I have had 30 year old cars with OEM CAT's still working fine, sensors on the other hand, needed to be replaced.
Jonfit
Jan 2, 2026 06:49 AM
