Shifting MT when engine is off?
Old Jan 26, 2007 | 06:35 PM
jkandell's Avatar
A beginner's MT question: Is it normal that when the engine is off my manual transmission shifts without a clutch? When the engine's on the clutch has to be engaged for vertical movement, though it still seems to move side by side without it. I'm probably being paranoid because a friend drove it a couple miles and I could swear it's not shifting as smooth... :-)
Old Jan 26, 2007 | 07:00 PM
gettinafit's Avatar
NORMAL it is!
Old Jan 26, 2007 | 07:06 PM
Tankist's Avatar
yes, it is normal that you will be able to shift into SOME gears under the condition you described, sinse some of them will be aligned just right. some of them however will be "unshiftable into" since they are missalighned and our engine is not turning to align them.
however dude, not to insult you or anything but you need a good reading about how it all works if you ask questions like this one. search for manual transmition on Wiki for example and read the section about syncronised gearboxes. since you drive manual i think you and your driving can only benefit from that knowledge.
Old Jan 27, 2007 | 05:47 PM
Gordio's Avatar
I don't think that's necessary. I think I know how to drive a stick shift fine, but I don't even know what a clutch or a transmission looks like on the inside. IN electrical engineering, they use a concept called black box concept. It says you don't need to know how a device works. What is important is you know how to use it or how it behaves, but not worry what is inside the mystery box.
Old Oct 16, 2007 | 02:04 PM
07fitster's Avatar
It seem's like you know what your talking about.....I'm shifting up to 3rd gear and give it a little bait of gas and let off and it make's a cutchhhhhhhhhhh noise only when slowing down?..its shuts up when you gas it and its getting worse, 2nd and 4th are starting to do the same....I have a friend and he grinds gears, but i think thats on him not driving it right....would you say i might have a re-call on my hands or what?? input would help..thanks.
navila17
May 17, 2016 09:47 AM
Mrksstk
Apr 7, 2014 03:50 PM
Steverino
Mar 27, 2013 09:42 AM
Skyburst
Feb 14, 2012 08:43 PM
Giggles
Jul 17, 2008 06:20 AM
