fujita ca intake help...
Old Feb 11, 2007 | 07:37 AM
jezzy's jazz's Avatar
yo all, recently purchased a fujita ca intake from AJ..
currently in the middle of installation but realised that the coolant hose that needs to be replaced is welded to another hose.. i got a UK spec jazz GD1..
anyone know if the oem hose can be kept on instead of replacing it??
thanks
brian
Old Feb 12, 2007 | 05:33 PM
cheers claymore, i will look into it.. or how about disconnecting the hose but leaving it in, but still replacing them (if u know what i mean).. because the hose is welded together i cud simply leave it there disconnected under the hood??
Old Feb 13, 2007 | 09:30 AM
gettinafit's Avatar
I have the fujita CAI, and I left the breather tube hanging! I just used a rubber hose from valve cover to pipe, that's it. I didn't change the coolant tube.
It's fine, not necessary!
Old Feb 17, 2007 | 04:37 AM
thanx guys for the help, going to go out now an fit it, will keep yous posted...
Old Feb 20, 2007 | 05:43 PM
i finally got the induction on a few days ago an must say its pritty impressive..
couple of probs tho, my filter is sitting directly behind the fog light therefore i do not have enough room to line the filter up with the pipe..
anyone suggest i remove the fog light temp until i fit the filter proper?!
as for the hose pipes, i kept the coolant one oem but replaced the other..
overall im pritty chuffed with the installation, little low on the mpg due to heavy right foot, hehe...
egw84
May 20, 2016 02:14 PM
wzlfit
Apr 4, 2015 06:26 PM
s0x
Oct 13, 2014 05:41 AM
pokems23
Aug 2, 2014 09:36 PM
bdogpot
Nov 27, 2012 09:31 AM
