tick tick sound while "cold"
Old Feb 19, 2007 | 05:30 PM
bestfit's Avatar
well.. it has been cold here recently and every morning when i start my fit.. i hear tick tick tick (fast beat about 2-3 time every second).. i think it is "valve" sound.. once the car warms up ... it disappears...
is it normal?
Old Feb 19, 2007 | 05:44 PM
MarkB's Avatar
Wrong sub forum but.... If it only ticks at idle it's the injectors. when you rev it up does it go away at higher rpm? Lifter tick doesn't care what rpm you are at. I've heard my share of bad or un oiled lifters. I also think that the SOHC has more noise than DOHC. That may just be my opinion though.
Mine does that tick when it's cold to. I don't think it's a big deal. is this your first honda?
Old Feb 19, 2007 | 07:09 PM
Fit of RAGE's Avatar
I'm thinking that it's lack of oiling. If the engine is cold, the oil is thicker and untill the engien warms up, the oil won't lubricate as much. Now, 4 cylinder Honda's are naturally noisey. it has to do with the valve train setup and the injectors like MarkB said. Regardless, it's not important and not a serious issue. If you want, try puting a lighter oil in and see if it goes away.
Old Feb 19, 2007 | 07:13 PM
MarkB's Avatar
I think the big test is if it goes away when you rev it. Cars will always make some sort of sound. Put an intake and exhaust on the car and you wont hear it anymore
Old Feb 19, 2007 | 10:31 PM
bestfit's Avatar
Thanks for your advices.. i too thought it was not serious issue but just wanted to double check on that...
my fit has 1700 miles now.. it recently got very cold.. below 20F and i just noticed it... the temp will go up starting tomorrow... i will see what happens..
thanks anyways..
great forum...BTW
Twzle
Oct 21, 2017 04:44 PM
willy65000
Nov 19, 2011 05:25 PM
der Mond
Jul 3, 2011 09:29 AM
Kwonye
Jul 12, 2010 07:11 AM
--Mike--
May 14, 2009 02:00 AM
