Sponsored by:
Sponsored by: CARiD
This Rod Knock?
Old Mar 12, 2007 | 03:43 PM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
This Rod Knock?
I wasnt really sure where to post this. Today Im in the drive-thru for Chick-Fil-A. (Yummm) Im pulling up to the window. Rev up to about 1800-2g's and slowly pull up when I hear a knocking.
Right away Im like; "OMG, rod knock!"
They tell me my food will take a minute so I sit there revving slightly to 2000rpms, letting off and revving again. I hear it everytime. Its not going away. It deff. sounds like its in the block or at least the lower half of the motor.
Its really faint but I can hear it everytime. I guess I'll take it in on Wens since its my day off. This is going to really suck. Id hate to have motor internals warrantied on my VIN. Well. I hope they warranty it.
Old Mar 12, 2007 | 04:50 PM
KnifeEdge_2K1's Avatar
what's rod knock ?
Old Mar 12, 2007 | 08:14 PM
Spule 4's Avatar
Mine makes a bit of top-end noise that you can hear when you are up against a wall/building/cliff etc.
Trust me, a rod knock you will know when you hear it.
BTW, I noticed the tag on your Mazda. Are you Dutch?
Old Mar 12, 2007 | 08:24 PM
Spule 4's Avatar
Originally Posted by KnifeEdge_2K1
what's rod knock ?
Spun rod bearing, the slap makes the noise:
YouTube - Rod knock
When they get quiet is when you worry. I had a Toyota 5S-FE do that once, could see daylight through the block in three places below piston #4 once I extricated the motor.
Old Mar 12, 2007 | 10:47 PM
quangalang's Avatar
i say it's just a little valve tick, i can hear mine a little bit but i dont think too much of it because it's kind of normal
Old Mar 12, 2007 | 10:52 PM
nothx's Avatar
what kind of gas do you use?
Old Mar 12, 2007 | 11:16 PM
quangalang's Avatar
idk about gx6gt89 but i use 87 octane, and no it's not detonation if you're thinking that
Old Mar 12, 2007 | 11:39 PM
Spule 4's Avatar
Antiknock....
Old Mar 13, 2007 | 02:55 PM
Posts in the NUUDE
I use 87 also. I dont think the Fit needs anything higher unless you get a lot of mods maybe.
I guess it isnt knock... Ive heard knock before. I was just thinking since the Fit is a 1.5L the rods are tiny. So knock wouldnt make that much noise.
No; Im not Dutch. I got a few tags sent to me from a friend of mine from the Netherlands. Hes a 626 Coupe freak!
I wish I didnt give my friend (VBP RSX) my US sized Dutch tag. It would look sexy on my Fit.
Old Mar 13, 2007 | 10:56 PM
Hondady's Avatar
I hear this to every so often. I beleive its the evap canister purge valve opening and closing. Sounds like a valve tap but isn't.
Old Mar 14, 2007 | 12:33 PM
milano sol's Avatar
yeah for some reason these lil motors tend to get pretty noisy
its more than likely just the valves then tap pretty loud haha. so yeah shouldnt be anything to worry about.
Old Mar 14, 2007 | 12:48 PM
iwillfit
Guest
Posts: n/a
If it sounds loud, or unusual should you have the valves adjusted? I didn't think you had to adjust valves like you used to on old cars. I checked online with Honda owner link and it says that the valves should be adjusted only if they're noisy. I notice it during idle being louder than I remember. What do you guys think?
Old Mar 14, 2007 | 01:02 PM
Posts in the NUUDE
Every Honda motor is loud. I guess it just bothered me somewhat since its brand new.
My Mazda is OLD and the motor is quiet.
Old Mar 14, 2007 | 02:48 PM
805FitSport's Avatar
ITS THE EVAP PURGE VAVLE trust me.... i just bought a new one cause mine is out of control loud..... i thought it was a exhaust vavle that tighthen up.... i took everything apart and checked all the tolerences on the valves and one was a bit tight but everything else was fine. i put everything back together and the ticking was still there. so i diconect the purge silenoid while the car was idleing and bam the noise went away... the part from honda is about 75 bucks.... mine is ticking really bad so im replacing it.
Old Mar 14, 2007 | 07:12 PM
Spule 4's Avatar
I saw your Florida location right after that post.
I also wondered, as the tag on your car was issued in 1991 and your car was a 1989. I have stacks of Dutch tags (private, govt, dealer, export, military, etc.) but the new EU plates are hard to get. Yeah, you should have kept the US sized one.
Old Mar 15, 2007 | 06:48 PM
Posts in the NUUDE
I still have another one. Its a duplicate. I dont want to rock the same tag as him, kinda dumb. :/
Old Mar 15, 2007 | 08:52 PM
Hondady's Avatar
Your right it is the evap purge valve.
Old May 18, 2007 | 03:35 PM
edorwart's Avatar
I had exactly the same problem on my 1995 Mitsu. Eclipse GS-T. It was the evap can solenoid. I bought a new one and it fixed the problem. I sure did sound like a noisy lifter though!
CptanPanic
Aug 30, 2015 10:01 PM
Juliet372
17
Feb 19, 2010 10:05 PM
Elias
Mar 10, 2009 11:34 PM
runbikerun
Jan 23, 2009 04:56 AM
