Re: 2004 Odyssey shuts off when stopped
Old May 4, 2005 | 11:16 AM
All_Star_Tio
Guest
Posts: n/a
I just had our 2004 Odyssey serviced under a recall notice related to the
fuel pump connector. The recall postcard we received said that if the
connector began to corrode, the car could stall.
I don't know if it is related, but you may check into that if you haven't
had your car serviced for this recall.
Good Luck!
"mmhamilton" <mmhamilton@verizon.net> wrote in message
news:Xns95F14D5422527mmhamiltonverizonnet@199.45.4 9.11...
> My wife's 2004 Honday Odyssey (6K miles) sometimes just shuts off when she
> comes to a stop. No lights on the dash or anything. It only happens once
> or twice per day. This started happening at around 5K miles. She also
> said it happened while she was moving slowly one time which is really what
> scares me. I took it to the Honda dealership and they could not get it to
> replicate. They did an Idle Relearn, checked for air leaks and sensor
> connections and found no problems.
> I've called and scheduled another appointment with the dealer, but the
> problem is getting this to happen on command. The guy wasn't too thrilled
> and said he can't have a tech driving around all day. I'm just looking
for
> some suggestions as to what could be causing this and how I should pursue
> this. Could it be a faulty ignition switch? Idle Problem? Does this
fall
> under Lemon laws? I bough the car in PA and it is registered in WV so
I'll
> have to research where this falls. Thanks for any input :)
JupiterJoe
Sep 22, 2014 11:41 AM
jofitjo
May 28, 2010 11:05 PM
Tom
May 15, 2005 07:30 PM
anony
May 4, 2005 11:16 AM
