2003 Pilot Clunking Calipers
Old May 4, 2005 | 11:16 AM
John Casey
Guest
Posts: n/a
Has anyone had any experience with the brake calipers clunking on the first
brake application after changing direction? The dealer says this is normal
for this car. I told them it's bull for a $35K car to make that kind of
noise.
Thanks,
John C.
disallow
Guest
Posts: n/a
Re: 2003 Pilot Clunking Calipers
That happens on my 98 civic. Could be faulty
installation of brake pads, but probably normal.
t
John Ings
Guest
Posts: n/a
On Wed, 9 Feb 2005 19:45:37 -0500, "John Casey"
>noise.
http://www.tegger.com/hondafaq/Brakes.html#click
Abeness
Guest
Posts: n/a
>>noise.
Unfortunately the link to the PDF there is broken.
zonie
Guest
Posts: n/a
My 04 accord does the same thing. Im not going to worry about it.
Jale
Guest
Posts: n/a
In article <nbjl0118rj9lgfj5shjcln26q1tks1cm5f@4ax.com>,
Better yet: The TSB 032604 is quite specific:
Component Description:
17. SERVICE BRAKES, HYDRAULIC
Bulletin Number: 032604
Bulletin Date: MAR 2004
Vehicle: 2003 Honda Pilot
Summary:
REAR BRAKE SHIM KITS FOR THE REAR BRAKE CALIPERS WHICH MAY CLUNK THE
FIRST TIME THE BRAKES ARE APPLIED AFTER CHANGING DIRECTION FROM FORWARD
TO REVERSE OR VICE-VERSA. *TT
TeGGer®
Guest
Posts: n/a
Abeness <news@nada.x> wrote in news:SOWdnY9MQMtFTZffRVn-3g@rcn.net:
>>>first brake application after changing direction? The dealer says
>>>this is normal for this car. I told them it's bull for a $35K car to
>>>make that kind of noise.
Yep. I just fixed it, sorry. When I updated the tsb folder with a pile of
stuff I was given, I forgot to update that link.
In any case, there's no index file in the tsb folder, so raw directory
listings are possible:
www.tegger.com/hondafaq/tsb
TeGGeR®
TeGGer®
Guest
Posts: n/a
Jale <Nospam@please.com> wrote in news:Nospam-
EE5402.20324809022005@news.west.cox.net:
> Summary:
Yes. The Honda number is 04-019.
http://www.tegger.com/hondafaq/tsb/Pilot/04-019.pdf
If you want a raw directory listing, just snip everything up to "tsb" in
the URL above.
TeGGeR®
TeGGer®
Guest
Posts: n/a
"John Casey" <jcasey4@optonline.net> wrote in
news:PbyOd.176$Vr6.146@fe11.lga:
T'ain't normal. There's a TSB.
TeGGeR®
motsco_ _
Guest
Posts: n/a
> noise.
> Thanks,
> John C.
I know some newer CR-Vs have that problem, but you could sign in and
search the Pilot forum and articles here:
http://www.hondasuv.com/stg/viewforum.php?f=26
'Curly'
John Ings
Guest
Posts: n/a
But is it harmful? Or is the fix just to placate fussy customers?
Abeness
Guest
Posts: n/a
Thanks, Tegger.
TeGGer®
Guest
Posts: n/a
John Ings <nodamned@spam.org> wrote in
news:drsm015m7c25t0emsi1c91uq5rvdhdaes0@4ax.com:
No harm at all. Just annoying as hell. It's solely an NVH issue.
TeGGeR®
John Casey
Guest
Posts: n/a
Thank you all for your help. Your links to the various sites are most
useful.
John
"motsco_ _" <"motsco_ _"@interbaun.com> wrote in message
news:420B0541.6010701@interbaun.com...
>> first brake application after changing direction? The dealer says this
>> is normal for this car. I told them it's bull for a $35K car to make
>> that kind of
>> noise.
>> Thanks,
>> John C.
> 'Curly'
jim beam
Guest
Posts: n/a
> noise.
> Thanks,
> John C.
small clunking as described is normal. big is not. check to be sure
the holding springs are in place.
TomP
Guest
Posts: n/a
No and yes.
Tp,
-------- __o
----- -\<. -------- __o
No Lawsuit Ever Fixed A Moron...
Ewin Alcarde
Feb 25, 2015 12:17 PM
garciabe
Oct 7, 2007 06:46 AM
Oofie
Jan 31, 2007 03:00 PM
thomas.jacobs@dva.state.wi.us
Oct 6, 2005 09:30 AM
santa19992000@yahoo.com
Jun 10, 2005 06:34 PM
