Header & full catback exhaust worth getting?
Old May 24, 2007 | 06:30 AM
ride_the_pony69's Avatar
Just wanted to know if these were both worth getting? I don't want 2.5 inch piping on the exhasut because I don't want to lose performance. What size is the stock piping? Should I get the exhaust and keep the stock header? Or just get and axleback or get everything? Help!
Old May 24, 2007 | 11:32 AM
Civtegrar's Avatar
IMO its not worth getting the header nor the exhaust .For our fit if u want power i say go turbo or k20 swap.save your money and go for bigger and better things.
Old May 24, 2007 | 07:07 PM
Originally Posted by claymore
There are SEVERAL THREADS in the exhaust forum just waiting for you to pull up a chair and read them to answer your questions. Like why you think you would lose performance with 2.5 ???
Thank you for pointing that out but I was in a hurry this morning when I wrote that thread so SORRY if I didn't check to see if there was another thread on it. Plus there is not enough info on this forum to really get the answers I am looking for.
Old May 24, 2007 | 07:21 PM
Why do I think I would lose power with a 2.5? Well lets see, you lose back pressure, something you need with a N/A car and not having certain internals like forged pistons and rods, cams and valvetrain or even a turbo there is no reason to have piping that big on this car because of the engine size. Now I could be wrong and if I am by all means correct me. I used to have a GSR integra so I know a little something about hondas. I have a suby now and am now getting back into the honda game so I am a little rusty.
Old May 24, 2007 | 08:23 PM
Civtegrar's Avatar
You are right you lose backpressure u lose low end power and u gain at high end. 2.5 is cool for n/a but if u going for turbo i suggest 3" pipe.there is no reason for me to hook up our small motor cuz most of us got this car for gasoline efficiency for a daily driver and most important is the reliability .if you want a fast car get like another older car and hook it up for speed all you want.i learned this the hardway before i use to have a 99 civic b18c turbo and all i modified that car so much that it can do 11.5 1/4 et but i lost the gasoline efficiency and the reliability something always break in the car and i fix it right away and one day i just got sick and tired of fixin it so i sold it for less than half that i spend on it yup it suck when something that you owned start owning you.
Old May 25, 2007 | 04:02 AM
Chikubi's Avatar
Well, Claymore is right, there are actually quite a few threads that have the info you're looking for -- you've just got to wade through them and pull out what you need.
Stock piping is 50mm. Skunk2 makes a 60mm system in addition to a 50mm, and like you've already brought up, they only really recommend the 60mm for FI setup and the like, so you're better off sticking with stock diameter for N/A in my opinion.
Whether they're worth it or not depends on a lot of things. What are you expecting to gain from making the mods?
Old May 28, 2007 | 12:00 PM
Ok I am gettting an exhaust soon but don't know if I want an axle back or cat back. Should I go with 2.5 inch piping or stay with the stock piping size? Want to have good performance. Also here is a catback I found on ebay for $135.
eBay Motors: JDM N1 CATBACK MUFFLER EXHAUST SYSTEM 07 HONDA FIT NEW! (item 280118064167 end time May-30-07 16:50:13 PDT)
Old May 28, 2007 | 02:01 PM
Chikubi's Avatar
Ok I am gettting an exhaust soon but don't know if I want an axle back or cat back. Should I go with 2.5 inch piping or stay with the stock piping size? Also here is a catback I found on ebay for $135.
Rule #1: "Want to have good performance." and ". . . here is a catback I found on ebay for $135." don't mix. Don't even think of buying a no-name Ebay exhaust -- save your money and buy quality like Spoon, Skunk2, Tanabe, etc. You won't regret it cause you get what you pay for in the end. Besides, how can you trust a seller that has "100% money back guarantee" written all over the description, then has "All sales are final no refund or exhange is offered, no shipping cost will be refunded under any circumstances if item is defective you need to contact manufacturer." written in the fine print.
Now that we got that out of the way, if money is an issue, buy a good axleback first, then get the center-pipe to make it a catback later when you can afford it. You can do that with Spoon, J's, A-spec, Skunk2, and if you stay with the stock piping diameter then you can mix and match if you like -- i.e. Tanabe muffler w/ Spoon b-pipe. If your heart is absolutely set on 60mm (2.5") piping then the Skunk2 60mm setup is your only recourse, though unless you're planning on going FI soon it's a waste and will probably hurt your performance more than anything else.
Old May 28, 2007 | 02:06 PM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
From what Ive header that listing is wrong. The piping is 2.25in; people have asked him.
And theres nothing wrong with that exhaust. Now what Id suggest is change the muffler. Do NOT use that muffler because Im sure its cheap and will sound cheap. Buy a nice axle-back to cap off the end. Im either going to get the exhaust listed above and use it as a Bpipe or the Megan.
Looked at the link... FUNK THAT! I got quoted $200 shipped for the Megan.
Old May 28, 2007 | 02:43 PM
Well there is a guy on here that I am going to get an Aspec axleback from. I guess I could buy that ebay exhuast and just use the mid section.
Old Jun 11, 2007 | 06:30 PM
805FitSport's Avatar
OMG i know you from IWSTI... im xfactorSTi on that forum... but yea choose your exhaust system well... be carefull how big you go with the size of the exhaust unless you get a AFC and richen the mix up a little or you will go lean.
Old Jun 11, 2007 | 08:58 PM
Lol! It's a small world huh?
Old Jun 11, 2007 | 09:36 PM
Posts in the NUUDE
Since this thread is back up... Is this true? Why would companies make aftermarket exhaust systems in the same size piping as OEM?
I think OEM piping is smaller.
Old Jun 12, 2007 | 02:11 AM
SPON FIT's Avatar
im pretty sure that oem is 45mm
Old Jun 12, 2007 | 01:55 PM
OEM is 45mm... its tiny...
lakia5524
Oct 10, 2012 08:38 PM
xorbe
Jun 9, 2008 02:20 AM
bigtymer8700
15
Mar 18, 2008 06:33 PM
explosivpotato
Jul 3, 2007 08:35 PM
konradh
Apr 3, 2007 02:17 AM
